Local Time 02:06 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CG’s CMM1 and CMM2 PCB sizes?
Posted: 02:44pm 02 May 2013
@ CG: are the PCB's for the CMM1 and CMM2 the same size, and more importantly, are the mounting holes in the same place?
I am just about to build the prototype into a case, but any further CMM's I get from you would be the CMM2, not the CMM1 that I have now, and I just want to check that the CMM1's mounting holes are in the same place as the newer CMM2.
They look the same in the photos, but that does not mean that they are in the same place.
Thanks.Edited by Grogster 2013-05-04
CircuitGizmos
Posted: 03:31am 03 May 2013
They are the same size/shape and the "stuff that counts" hasn't moved.
Posted: 12:56pm 03 May 2013
Excellent - thanks, CG.
