Local Time 08:21 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CGColorMax with Linux
hitsware
Posted: 08:36am 11 Apr 2013
I've been using HyperTerm with XP
with success, but am going to try
Linux. How do I get that going ?
I'm using Zorin distro, so I could
probably use Wine w/Hyperterm, but
would like to try a more native
Linux approach.
Posted: 11:49am 11 Apr 2013
I don't know Zorin but try any of these
screen
putty
minicom
picocom
gtkterm
gterm
moserial
You need to know the name of the device (likely something like /dev/ttyACM0) and to have permissions to access it - try as root initially if need be.
If you don't know the device, look at the output from dmesg
I use
screen /dev/ttyACM0 115200
or
screen /dev/ttyUSB0 115200
for various boards
and have udev set to detect the boards then assign permissions to group plugdev (I'm a member)
google will get you details of any of the above
The 115200 is the baud rate, sorry can't recall what these boards default to!
JohnEdited by JohnS 2013-04-12
