Local Time 08:15 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Android app mouse (extension Raros’ idea)
MM_Wombat
Posted: 07:05pm 30 Mar 2013
I have written an android app using app inventor, that connects to the MM via serial at 1200 baud. I then used Raros' code (modified his code slightly, see his thread)..to move the mouse around..
Works very well.
Had to set left and right buttons on a toggle loop, so the canvas can send the data needed.
Raros' previous Thread.
Regards Dennis
Keep plugging away, it is fun learning
But can be expensive (if you keep blowing things up).
Maximite, ColourMaximite, MM+
