Local Time 08:05 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Maximite color: found little bug
Juri74
Posted: 02:07pm 11 Mar 2013
hello!
i think i found a bug in v4.3
try this code:
print hex$(16777212)
FFFFFC
print hex$(16777213)
FFFFFE
print hex$(16777214)
FFFFFE
print hex$(16777215)
1000000
print hex$(16777216)
1000000
and so on....
please could be fixed in the next firmware release?
thanks
aargee
Posted: 02:35pm 11 Mar 2013
As well as posting here you might want to send Geoff an email directly at:
projects@geoffg.net
- Rob.
CircuitGizmos
Posted: 03:04pm 11 Mar 2013
You are at the limit of the way a number is represented. Not in hex it looks like this:
print 16777212
print 16777213
print 16777214
print 16777215
print 16777216
> run
1.67772e+07
1.67772e+07
1.67772e+07
1.67772e+07
1.67772e+07
From the manual:
The range of integers (whole numbers) that can be manipulated without loss
of accuracy is ±16777100.
shoebuckle
Posted: 09:09pm 11 Mar 2013
  CircuitGizmos said   You are at the limit of the way a number is represented. Not in hex it looks like this:
print 16777212
print 16777213
print 16777214
print 16777215
print 16777216
> run
1.67772e+07
1.67772e+07
1.67772e+07
1.67772e+07
1.67772e+07
From the manual:
However if you write it as
Print Format$(16777212,"%8.0f")
Print Format$(16777213,"%8.0f")
Print Format$(16777214,"%8.0f")
Print Format$(16777215,"%8.0f")
you get
16777212
16777213
16777214
16777215
@geoffg
Incidentally I just checked the Hex to numeric conversion and we get a similar problem in v4.3. Hex FFFFFD is converted incorrectly.
Print Format$(Val(&HFFFFFC"),"%8.0f")
Print Format$(Val(&HFFFFFD"),"%8.0f")
Print Format$(Val(&HFFFFFE"),"%8.0f")
Print Format$(Val(&HFFFFFF"),"%8.0f")
Gives
16777212
16777214
16777214
16777216
Cheers,
Hugh
Juri74
Posted: 02:05am 12 Mar 2013
i read that in the manual, and it looked very strange.. i tough that the numeric accuracy would cover the entire 24 bit range... too bad, i've to rethink entirely my next app...
thank you all
Posted: 03:31am 12 Mar 2013
  shoebuckle said  @geoffg
This is not a bug, it is the inherent inaccuracy when you try to store too large an integer in a floating point number. Use a smaller number and there will not be an error.
Posted: 06:00am 12 Mar 2013
It's what I'd call a bug.
For IEEE754 binary32 (old name single-precision), Hex FFFFFD ought to end up as the 4 hex bytes (little endian) FD FF 7F 4B so that sign bit is zero, exponent 23 and so on. It should then print properly, too, i.e. as 16777213.
Similarly, Hex FFFFFF ought to work and be 16777215 (again, internally exponent 23).
I can't tell from what's reported whether VAL doesn't quite work or FORMAT$ doesn't (possibly both).
Unless I've missed something.
Now... it's hard to get these worst-case values right and the doc says what's allowed, so in a way it's not a bug...
JohnEdited by JohnS 2013-03-13
shoebuckle
Posted: 11:40am 12 Mar 2013
Fair enough. I hadn't thought of that.
Hugh
Posted: 01:58pm 12 Mar 2013
Except it's wrong.
Posted: 09:01pm 12 Mar 2013
I would 'vote' for an overflow error as it is an error condition.
It is an artifact of using a float to represent an integer. by range checking this error can be trapped.
Posted: 09:42pm 12 Mar 2013
There's no overflow in the values I posted about.
JohnEdited by JohnS 2013-03-14
