Local Time 08:05 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : IR Transmitter/copier
Posted: 05:16pm 10 Mar 2013
Hi Fellas,
Before I reinvent the wheel...
I have a 10w RGB LED spot light in my garden like this one, except mine works off 12Vdc.
RGB SPOT
It works really well but it powers up in a sharp sudden change of colors which I find really annoying. The remote allows me to change to a fade pattern which I find quite pleasing..
As it stands, the remote only seems to work from about a metre (1 yard) away and needs to be directed directly into the front of the light. This is impractical as I have to get my Indiana Jones gear on and use a machete to hack my way in each and every time I turn my lights on. This is impractical, so I have a couple of options I am considering.
1. Hack the remote to power on when my lights are powered on and auto trigger the appropriate button after a suitable delay (havent determinind that yet but may be as high as 30s or as short as 1sec). This would probably be easist and I dont care about the remote anyway (and the entire lamp and remote is only about $22)
or
2. A small (8pin) pic chip that I can get to read my `fade' code and store it and then programmed to shoot the code out to an IR LED after my delay..
Now I cant program in C but I wonder if similar things aren't already out there.
Any ideas?
jman
Posted: 06:00pm 10 Mar 2013
Hi Mick
Take a look here http://www.rentron.com/picbasic/ir_chips.htm
Some really good IR Info there
Posted: 10:10pm 10 Mar 2013
Thanks John,
That looks like what I need.. It doesnt have all the answers to my questions but I might be able to nut it out.
Cu
Bill.b
Posted: 11:20am 11 Mar 2013
Hi Mick
you could use a picaxe with an IR sensor, this is a very simple circuit
and the programming is very similar to mmbasic.
you only need a tv remote to operate it.
only one channel would be required and if the MOSFET was mounted on
a heatsink, you could control the light directly.
also the oultput can use PWM control if you require dimming.
Posted: 01:01pm 11 Mar 2013
Hi Bill,
Thanks for the suggestion of the Pic Axe... I think I will go with John's suggestion above.
I have (I think) worked out how to use it..
I think I set it to receive mode and set latching outputs and read the IO pins to see what 8 bit code is being transmitted via my remote. Then I set it for transmit and link the IO the appropriate code and set for pulse and it will transmit it... I have everything I need except a Pic chip.. My pickit3 has a few adapter boards with ZIF sockets so I think I can program them ok... and I checked a Pic16F628/7 is only a couple of dollars on eBay. I only need to work out a delay cct for it to wait before it transmits.. Or change the code in PBP to do it there (prob best)
It will be an interesting project.. I am going away next week so I wont order my PICs till I get back.
Thanks John and Bill,
