Local Time 08:05 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM Baud Rate
MM_Wombat
Posted: 10:53pm 08 Mar 2013
Is there any way to get a 115200 baud rate on a MM or CMM?
To connect to a Microchip/Roving Networks RN 42 XV bluetooth module I need 115200 serial link..
Dennis
Keep plugging away, it is fun learning
But can be expensive (if you keep blowing things up).
Maximite, ColourMaximite, MM+
Posted: 11:04pm 08 Mar 2013
From the help file:
‘baud’ is the baud rate, either 19200, 9600, 4800, 2400, 1200, 600, 300 bits per second. For COM3 and COM4 (DuinoMite only) it can be any number from 300 to 460800. Default is 9600.
djuqa
Posted: 11:43pm 08 Mar 2013
That module will work with uart speed as low as 1200bps
VK4MU MicroController Units
cwilt
Posted: 05:58am 09 Mar 2013
You will have to set the baud rate on the RN-42.
Usually $$$ with no return enters command mode.
I think the command is SU,19.2
Going from memory, but can not remember command to save it.
MM_Wombat
Posted: 02:02pm 09 Mar 2013
@djuga &cwilt.
I have connected the module through my pc bluetooth. com9 for outgoing and com10 for incoming. The pc is set for rni-spp. Using putty to connect on com9 with settings 115200,8,0,1,none i can connect. led goes solid. type $$$ and nothing. no 10 flashs/sec led.. tried many times. open com10 in putty with no returned text when typing in com9...short tx and rx on module together and get returned text in com9 window but still no command mode.
I have succesfully connected the module through my phone using app inventor and the arduino. still no luck with the command mode, and i send the command straight after the connection.
Will have to use MM to connect while driving gpio7 high. this sets the baud rate to 9600....maybe then i can get into command mode.
Baud rate command is SU,(first two number of desired rate) ie.. SU,96
Reset command is R,1
Regards DennisEdited by MM_Wombat 2013-03-11
MM_Wombat
Posted: 03:39pm 09 Mar 2013
@Tassyjim
If I got a DuinoMite and flashed my MM firmware(need my spiDMD() command) would the com3 and com4 still be able to be set to 115200?
If not , I will just have to drive GPIO7 high to force the module to a 9600 setting. I don't know why I am having so much trouble.. Hopefully the next module will work better....
Dennis
I want to be able to change DMD panel with an android phone over bluetooth...
Posted: 05:19am 10 Mar 2013
I thought the device had a jumper for a low baud rate.
