Local Time 08:05 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Right ALT Key locks Maximite?
JonS
Posted: 04:57am 08 Mar 2013
Continuing with the Keyboard issues; I have noticed why, well more when, one of more serious problems occurs.
From time-to-time I've had keyboard lockouts where some keys still work, Function Keys for example and a couple of others. However none of the main keys work so you have to cold-boot losing the current program.
My Keyboard has an ALT key to the right of the spacebar. When I tap this, and that’s whenever I tap this, the keyboard will lockdown and I have to reset. I presume this is the case for “AltGr” also.
Any chance this could be confirmed by a few others?
Hopefully it is not just my keyboard and as such can be fixed.
PS. I have read a few other posts where people have reported a similar issue
Many thanks
JonS - teamFUZE
Posted: 01:13pm 08 Mar 2013
I too was having KB lockout issues etc(see my other thread), but since I swapped the switchmode plug-pack for a transformer and linear regulator PSU, pretty much all my KB problems have vanished - for the moment, anyway - I am still monitoring the situation.
I have ALT keys either side of the spacebar on my current test KB, and pressing any of these, or even combinations like WIN+ALT does not lock the KB at the moment, with the current PSU choice. My menu program just exits from a sub-menu, back to the main menu, if you press any other key then what is on the menu choices, so I could go into one of the sub-menus, then press things like ALT keys and WIN+ALT etc, and in all my tests, the menu came back to the main menu, which is exactly what it is supposed to do.
Are you using a switchmode plug-pack to power your MM?
It was suggested to me in the other thread, that some of the switchmode plug-packs are noisy(electrically), so I swapped it for a transformer based regulated plug-pack, to see if that helped, and it certainly did seem to, as far as MY problems with the KB were concerned.
paceman
Posted: 02:01pm 08 Mar 2013
Jon,
Mine also has an "Alt" key to the right of the space-bar (and the left) and have never noticed a problem on any keys, including that and the function keys - my "Alt/C" produces an ordinary lower case "c" on the screen.
The keyboard is a bog standard, full size 10yr old "DELL Quietkey" PS2, Model: SK-8000.
The sticker underneath it says:
DP/N 035KKW Made in malaysia
DS/N MY-035KKW-38843-08F-6750 Rev A00
Mine is plugged straight into the Maximite and that is powered usually by a good bench 9v supply but also sometimes by my old NEC notebook from a USB port.
I use the same setup for both my original Maximite and my CGCOLORMAX1 without trouble.
Greg
Edited by paceman 2013-03-10
cosmic frog
Posted: 02:52pm 08 Mar 2013
There was a bug which caused this problem before V3.2c - "Corrected a bug that caused MMBasic to hang if the right ALT key was pressed on a PS2
keyboard configured as the standard US default layout."
See .Change Log for more info.
Dave.
shoebuckle
Posted: 03:13pm 08 Mar 2013
@JonS
I have Alt keys either side of my space bar. Pressing either of them doesn't lock the keyboard in fact it returns Ascii 139. My keyboard is a Logitech PS2 which I have had for some years.
Cheers,
Hugh
p.s. I am using a Laptop brick to power the mono Maximite.Edited by shoebuckle 2013-03-10
