Local Time 07:56 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Getting filenames from users?
Posted: 05:40pm 03 Mar 2013
Hi.
I have a line input for the filename, then try to put it into the command, and am getting syntax errors.
line input m$
if m$="" then goto start
open "B:\DATA\";m$;".TXT" for input as #1
The open command fails.
If I enter the command directly in the command prompt like this:
? "B:\DATA\";m$;".TXT"
Then if m$ was ABCD, then the print statement comes out as B:\DATA\ABCD.TXT
Shouldn't that be working?
EDIT: Found something in manual page 4 under expressions - trying it out...
EDIT: Disregard this thread.
added f$ into the mix:
f$="B:\DATA\" + m$ + ".TXT"
open f$ for input as #1
I'm having fun today. Edited by Grogster 2013-03-05
shoebuckle
Posted: 05:54pm 03 Mar 2013
Grogster,
Replace the semicolons in your Open statement with plus signs. This concatenates the three strings.
Hugh
paceman
Posted: 07:01pm 03 Mar 2013
Also, for one-line IF statements like the top example, you don't need the "THEN" just a GOTO or GOSUB.
i.e.
if m$="" then goto start.......can be:
if m$="" goto start
Edited by paceman 2013-03-05
