Local Time 07:56 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : BMP editor for making CMM BMP’s?
Posted: 10:06pm 28 Feb 2013
Paint does OK, but it is a pain in the backside.
No movable elements etc, so if you cut-and-paste things in paint, you then have to use the fill tool to correct the white spaces in the black background.
Does anyone know of an alternative drawing program which can save in 16 colour mode for the CMM?
Posted: 10:09pm 28 Feb 2013
Inkscape
It uses vectors and is actually a SVG 'editor'.
It can export to many formats. If the specific format is missing you can then use other programs to do that last step.
It probably cuts drawing time something by 90% compared to paint.
For manipulating bitmaps/pictures in many formats and converting/adjusting/exporting i use irFanView
Edited by TZAdvantage 2013-03-02
Posted: 10:45pm 28 Feb 2013
Cheers, mate!
vegipete
Posted: 04:18pm 01 Mar 2013
Paint.NET is a useful tool too.
Posted: 04:54pm 01 Mar 2013
Yes, that looks interesting too - I will check it out aswell. :)
To save time for anyone else wanting to try it, I found the download link here:
http://www.dotpdn.com/files/Paint.NET.3.5.10.Install.zip
