Local Time 07:43 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : (DM) MMBASIC 4.x compatible RTC for DM
psergiu
Posted: 12:08am 19 Feb 2013
Hi everyone.
Is there a way to add a DS1307 RTC chip to a DuinoMite in such a way that it will be used by MMBASIC 4.x for storing date & time ?
Or is there any chance that future MMBASIC releases will support a PCF8563 RTC connected on the UEXT i2c pins ?
Thanks a lot.
jman
Posted: 08:48am 20 Feb 2013
Hi
Search the forum
This has been done with both these chips
psergiu
Posted: 10:03am 20 Feb 2013
I could not find anything.
MMBASIC 4.x on the new Colour Maximite will save the time & date from TIME$ and DATE$ to the on-board DS1307 RTC clock and at startup will read the time & date from the RTC into the TIME$ and DATE$ variables.
The same thing happens on DuinoMite with the DMBASIC firmware where date & time will be saved to and read from a RTC chip connected to the UEXT connector.
What i am asking is - if i install the latest MMBASIC 4.x version on my DuinoMite, will MMBASIC be able to use my UEXT-connected PCF8563 RTC to automatically store & load the values for TIME$ and DATE$ ?
If using the UEXT RTC module is not possible, to which pins should i connect a RTC chip in order to have TIME$ and DATE$ set automatically, like on a Colour Maximite ?
I know that i can have some code to read the RTC & set TIME$ and DATE$ at startup in AUTORUN.BAS and that's what i'll do if MMBASIC won't be able to access a RTC connected on DuinoMite's pins directly
Thanks a lot !
CircuitGizmos
Posted: 10:11am 20 Feb 2013
On the 100-pin PIC32MX695 or PIC32MX695 the pins of interest for the RTC are pins 58 (SCL) and 59 (SCK).
Posted: 10:43am 20 Feb 2013
Hi Sergiu,
Support for a RTC is not compiled into the Duinomite version of MMBasic because there is not a single standard for the chip type and interface. Your only solution is to modify the source to your requirements or add support into the auto run.has.
psergiu
Posted: 11:08am 20 Feb 2013
Thanks Geoff.
If you're thinking of adding RTC support to the next versions of MMBasic for DuinoMite, the most standard RTC chip for this purpose would be PFC8563 on the UEXT-connected MOD-RTC as built by Olimex: https://www.olimex.com/Products/Modules/Time/MOD-RTC/
Why i am saying "the most standard": all the sites selling Olimex's DuinoMite, are usually also stocking MOD-RTC (Mouser, Digikey & Dontronics certainly do) so a DuinoMite most likely will be bought together with a MOD-RTC board.
Thanks a lot !
