Local Time 07:33 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic, Stacks, Queues and Lists
panky
Posted: 11:25pm 03 Feb 2013
Hi Folks,
Been playing around with the idea of using sub-strings embedded in a single string to create a stack or queue or list of strings.
Currently, I have limited it to a minimum sub-string width of 99 and the number of sub-strings being 250 with the added limit of width by depth =< 250. Eg. 5 wide x 20 entries, 1 wide x 250 entries etc.
It is only for strings at the moment.
As an example, the test code at the end of my code uses 3kB of storage and 13 variables. If I had used normal strings to do the same thing, I would have used over 40kB of storage and 750 variables.
The routines will have specialised usage but may prove usefull in some circumstances. The code is well commented and should be reasonably self explanatory.
My thanks to Tassie Jim for the idea of sub-strings from his Short Strings code - if a larger stack or queue is required, his short strings may be able to be integrated to the code here.
I make no claim to elegance in code nor space saving - just like having fun.
Hope it is of use to someone,
Cheers, Doug.
panky
Posted: 11:31pm 03 Feb 2013
Sorry folks - somehow missed the .zip upload.
2013-02-04_093110_STKUTILS.zip
Posted: 12:30am 04 Feb 2013
That is amazing Doug.
As you say, specialised... but also a sophisticated set of routines.
MM_Wombat
Posted: 09:41pm 04 Feb 2013
For Version 4.3 of Maxifont, I utilize the Character in each string variable.
Each Character has 8 bits, with 255 characters to a string, that is 2040 bits of info I can use for the font design. That is 31 font characters of 8x8 in one string variable. Luckily, Geoffg added the chain command which helped me shave 3000 bytes from the beginning of the Maxifont program.. So even more memory, to play with.. I hope to have the Monochrome and colour versions finished soon, and upload to the library..
my horizontal flip routine has three lines( four if you count the declaration)
x= &b10101010
x=(((x and &HAA)\2) or ((x and &H55)*2))
x=(((x and &HCC)\4) or ((x and &H33)*4))
x=(((x and &HF0)\16) or ((x and &H0F)*16))
then Print bin$(x) gives us (0)1010101
Regards Dennis
Keep plugging away, it is fun learning
But can be expensive (if you keep blowing things up).
Maximite, ColourMaximite, MM+
ajkw
Posted: 11:03pm 04 Feb 2013
Nice work on the bit flip Dennis!
It would be nice if you could format bin$ to show appropriate leading zeros
hint GG: print bin$(value,8) and/or print bin$(value,auto)
MM_Wombat
Posted: 11:17pm 04 Feb 2013
Can't take credit for the bit flip, got it from the bithacking website...
Dennis
PS: just use crackerjacks bin8$(byte_in) funtion from the bin8.bas library program..
ajkw
Posted: 11:37pm 04 Feb 2013
I have,in the past, always looped through a byte testing each bit and then rebuilding a new variable to flip the bits in the past before I came across crackerjack's test (byte_in And (2 ^ bit)) > 0 in his routines that is a way neater test than I had come up with in the past.
I always figured there must be a 'mathematical' way. Nice find!
edit. and Right$(String$(8,"0")+Bin$(byte_in),8)] will do me.
Anthony.Edited by ajkw 2013-02-06
panky
Posted: 11:52pm 04 Feb 2013
Hi Guys,
A bit of an update. Tidied the code a little and added numeric stack routines, create, push, pop and average.
Also added a text file with a more in depth explanation of each routine or function.
In real use, I would strip all comments, blank lines and the test code at the bottom with Jim's beaut MMEdit then merge the result onto the end of a program as callable subroutines and functions.
Hope this is usefull.
For Hugh, happy to have it added to the library if you think worthwhile.
Cheers, Doug.
2013-02-05_095128_Stack-Queue-List-Utilities.zip
shoebuckle
Posted: 12:09pm 05 Feb 2013
  panky said   For Hugh, happy to have it added to the library if you think worthwhile.
Cheers, Doug.
Looks great. I will add it.
Hugh
TinkersALot
Posted: 02:05pm 05 Feb 2013
Nice. Thank you for posting this.
