Local Time 07:18 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Help with File Handling
Nick
Posted: 11:29am 12 Jan 2013
Having trouble with some file handling.
The following program saves the variables S$,A and B to a file called "TEST".
S$="HELLO"
A=100
B=55
Open "TEST" For OUTPUT As #1
Print #1,S$,A,B
Close #1
Open "TEST" For INPUT As #1
Input #1,S$,A,B
Close #1
Print S$,A,B
When I read those variables back, I get...
HELLO 100 55 0 0
S$ has combined the A and B variables.
What's going on here?
NickEdited by Nick 2013-01-13
vk4tec
Posted: 12:10pm 12 Jan 2013
OK here is what is going on
On reading back,
S$ = "HELLO 100 55" and
A = "0"
and
B = "0"
On reading back, it does not know what you mean how does it know how to chop up the data ?
- Andrew -
Andrew Rich VK4TEC
www.tech-software.net
xraydude
Posted: 12:12pm 12 Jan 2013
I believe you might need to use comma delimiting when writing to the file?
i.e.:
Print #1,S$,",",A,",",B
Close #1
Ted
Ted Forrest
KB5CQF
vk4tec
I would doubt it even knows to write A and B to a file.
I normally convert variables A and B to "text"
You may do to put commas and then split on the commas
1. Convert A and B to strings
2. Write with commas
3. Split on commas
"HELLO,100,55"
Then split read on commas.
- Andrew -
Andrew Rich VK4TEC
vk4tec
Posted: 12:14pm 12 Jan 2013
  Nick said
S$="HELLO"
A=100
B=55
Print #1,S$,A,B
Close #1
Input #1,S$,A,B
Close #1
Print S$,A,B
At this point, s$ = "HELLO 100 55" and A and B = "0"
Hence you get "HELLO S$ A B " where A and B are zero
Andrew Rich VK4TEC
vk4tec
Posted: 12:17pm 12 Jan 2013
Or if you gurantee the sequence - write to lines 1,2,3 etc
write s$
write A
write B ( etc )
read s$
read A
read B
read s$
read A
read B
read s$
read A
read B
read s$
read A
read B
Andrew Rich VK4TEC
Posted: 12:24pm 12 Jan 2013
As pointed out by xraydude, you need to add the comma between items when printing if you want to read them in separately.
S$="HELLO"
A=100
B=55
Close #1
Input #1,S$,A,B
Close #1
Print S$,A,B
shoebuckle
Posted: 12:32pm 12 Jan 2013
Hi Nick,
It took me a while to discover what was going on too. What is needed is either a CR or a comma between variables in the output stream to separate values. If you write multiple values in a single Print statement, you must add a "," between each, but not after the last one. If you put each variable in its own Print statement, a separator is automatically added.
Below is the code I used in the Hearts & Bones game to load and save various parameters. You will see that I inserted a "," between each variable in the SaveGame subroutine. You don't need, and mustn't insert, a "," at the end of each statement as a separator is automatically inserted by the Print command unless you terminate the Print with a semi-colon.
I found this out by writing some print statements and looking at the resulting file with a text processor. There are a couple of file dump programs in the library, HexDump and TextLook, which will show you what's in the output file.
Cheers,
Hugh
LoadGame:
Print @(0,21*12) Space$(10) "Please enter your name so I can load your highest score,"
Print Space$(10) "starting number of bones and direction keys";
Input FName$
If Len(FName$)>8 Then FName$=Left$(FName$,8)
FName$=FName$+".xls"
Option Error Continue
Open FName$ For input As #1
If MM.Errno=0 Then
Input #1,HighScore
Input #1,UL,UN,UA,UR,LN,LA ' direction key assignments
Input #1,RN,RA,DL,DN,DA,DR,MK
Input #1,StartBones
Close #1
EndIf
Option Error Abort
GoSub ClearHelpText
Return
SaveGame:
Open FName$ For output As #1
Print #1,HighScore
Print #1,UL","UN","UA","UR","LN","LA ' direction key assignments
Print #1,RN","RA","DL","DN","DA","DR","MK
Print #1,StartBones
Close #1
Return
panky
Posted: 01:09pm 12 Jan 2013
Hi Nick,
Ran the test on DOS MMBasic v4 and in my tests it appears the issue is in the write to file area. The first Print #1,s$,a,b just writes all the variables as a continuous stream of text characters, converting the numeric variables to text with a leading space and ends with a trailing 0D 0D 0A
When it is read back with the input statement, this whole string is read back in as s$, so it appears that the first variable in the input statement gets everything in the file.
My reading of the MMBasic Manual indicates that this is probably correct although the use of multiple variables in the print #1 statement is useless.
On the SD card both data and programs are stored using standard text and can be
read and edited in Windows, Apple Mac, Linux, etc. An SD card can have up to 10 files open simultaneously while the internal flash drive has a maximum of one file open at a time.
If you need to store multiple variables, you need to seperate them yourself in some way and maybe do some numeric to string and vica versa conversion yourself.
eg. if your original print #1 statement were
print #1,s$,",",a,",",b
then a TAB COMMA TAB (09 2C 09) sequence would be inserted between the variables written to file and then the input statement will work correctly.
Not sure if this is a correct interpretation however I am sure Geoff can sort it or explain what we are doing wrong.
Cheers, Doug.
MOBI
Posted: 01:33pm 12 Jan 2013
  Panky said  and ends with a trailing 0D 0D 0A
I wonder why the two carriage returns (OD OD).
We used to use 2 CR in old teleprinter days because of the settling time of the print carriage to the left margin.
I would have thought that modern tecnology was faster than that.
On the file write/read multi variables, I found that with most languages if you want to separate variables on the one line, you have to manually put in delimeters as "," other wise the first read variable grabs the lot.
David M.
