Forum Index : Microcontroller and PC projects : MM Edit update
Posted: 08:13pm 04 Jan 2013
I have posted a new update for MM Edit.
I found that I was loosing a few file names in the File Manager if there were a large number of files present.
I think I have allowed enough time for the list to be generated but yell if you are playing around with large directories.
I have added another feature:
Highlight a Label, Sub or User Function name and you can jump to that code (and return to where you were).
I think this is useful as programs get larger and trying to remember what your functions do or when looking at other people's code.
The Syntax Help has the new V4.2 commands added.
MM Edit is available from:
http://www.c-com.com.au/MMedit.htm
