Forum Index : Microcontroller and PC projects : mmfour game
rambo55
Posted: 12:57pm 04 Jan 2013
I have try to run game mmfour in MM colour computer but this display is on the screen
[1]
Error: Invalid Character
CircuitGizmos
Posted: 01:16pm 04 Jan 2013
Works fine for me.
Open the MMFOUR.BAS file in a TEXT EDITOR and take a look at the first line. Perhaps there is a character that should not be there.
10: REM This programme was originally found on a demo
20: REM tape for the MicroBee computer. It was ported
30: REM to GWbasic and then Qbasic for use on a BBS
40: REM in 1995.
50: REM In 2011 yet another port, this time to
60: REM MMBasic to run on the Maximite computer.
70: REM Glenn Littleford. www.thebackshed.com
80: CLS
90: PRINT TAB(10); "F O U R - R O W": PRINT : PRINT TAB(15); "Ver 1.3"
100: PRINT : PRINT
(Note: What is with the colons?)
rambo55
Posted: 02:18pm 04 Jan 2013
  rambo55 said   I have try to run game mmfour in MM colour computer but this display is on the screen
[1]
All line are the same
40: REM in 1995.
80: CLS
100: PRINT : PRINT
Posted: 06:45pm 04 Jan 2013
That MMFour game is my little contribution to the Maximate library, along with MMPrey. I cant remember why the colons are there, I have a suspicion early versions of MMBasic required it, anyone remember?
I hope to find out who the original author of the Microbee version was, I would like to give them credit.
Posted: 08:03pm 04 Jan 2013
I did do a bit of work on one like this in my Microbee days.
I don't know the original source but it might have come from their magazine.
Here it is with the line numbers removed.
The only catch is that you use the < and > keys (, and .) and not the arrow keys!
Once I worked that out, all was working although I think it needs a larger font.
REM in 1995.
CLS
PRINT : PRINT
PRINT "Try to beat the computer in a simple yet addictive"
PRINT "game similar to CONNECT FOUR": PRINT
PRINT "Using the < and > keys position the arrow above"
PRINT "the column you want, then use the space key to"
PRINT "drop your marker. Press Q to quit."
PRINT : PRINT "Hit any key to continue"
RANDOMIZE TIMER
DIM t(11), s(44), n(7)
_Lbl190:
IF INKEY$ = "" THEN GOTO _Lbl190
CLS
e = 0: f = 0: g = 0
FOR a = 1 TO 44: s(a) = 0: NEXT a
IF s2 = 4 AND s1 = 0 THEN LOCATE 0, 165: PRINT "You really havn't got the hang of this, have you?"
IF s1 - s2 = 3 THEN LOCATE 0,165: PRINT "You think your good, dont ya!"
IF s2 - s1 = 5 THEN LOCATE 0,165: PRINT "Your loosing, ha ha."
FOR x = 1 TO 141 STEP 20
LINE (x, 20)-(x, 140)
FOR y = 20 TO 120 STEP 20
LINE (x - 1, y)-(x + 1, y)
NEXT
NEXT
LINE (1, 140)-(141, 140)
LOCATE 150,25 : PRINT "Four in a Row"
LOCATE 150,45 : PRINT "Scores...."
LOCATE 150,60 : PRINT " You:"; s1
LOCATE 150,70 : PRINT " Me:"; s2
LOCATE 150,80 : PRINT "Drawn:"; s3
LOCATE 150,100 : PRINT "Keys...."
LOCATE 150,115 : PRINT "< > to move"
LOCATE 150,125 : PRINT "[SPACE] to drop"
LOCATE 150,135 : PRINT "Q to quit"
CIRCLE (153,62),3
LINE (150,70)-(156,76),1,"BF"
w = 36
FOR c = 1 TO 7
n(c) = w
w = w + 1
NEXT c
c = 4
s4 = s1 + s2 + s3
IF s4 / 2 <> INT(s4 / 2) THEN GOTO _Lbl1170
_Lbl520:
m1$ = " My Move" : GOSUB _Lbl2000
IF g <> 0 THEN g = 0 : GOTO _Lbl190
v = 0: x = 0: y = 0: z = 0
_Lbl550:
j=j+1
IF j>7 THEN
j=0
GOTO _Lbl670
ELSE
c=c+1
IF c>7 THEN c=1
ENDIF
p = c
IF n(c) > 0 THEN GOSUB _Lbl1520
IF f <> 0 THEN j = 0 : GOTO _Lbl1030
GOTO _Lbl550
_Lbl670:
IF x <> 0 THEN c = x : GOTO _Lbl1030
IF y <> 0 THEN c = y: GOTO _Lbl740
IF z <> 0 THEN c = z: GOTO _Lbl740
_Lbl700:
c=INT(RND()*7)+1
IF n(c)<1 THEN GOTO _Lbl700
v = v + 1
IF c <> 4 AND v < 5 THEN GOTO _Lbl700
_Lbl740:
IF n(c) < 8 THEN f = 0: GOTO _Lbl1030
IF v < 10 THEN GOTO _Lbl870
IF v / 3 = INT(v / 3) THEN m = 1
m1$ = "Now what do I do ???": GOSUB _Lbl2130
IF v < 21 THEN GOTO _Lbl870
FOR t1=1 TO 200
LOCATE RND()*300, RND()*300
PRINT "?"
SOUND RND()*1000+20,20 : PAUSE 20
NEXT t1
PAUSE 1000
e = 1
GOTO _Lbl1420
_Lbl870:
n(c) = n(c) - 7
z = 0
GOSUB _Lbl1520
n(c) = n(c) + 7
IF f <> 0 THEN
f = 0
IF v < 9 THEN GOTO _Lbl700
ENDIF
IF z <> 0 THEN
z = 0
IF v < 6 THEN GOTO _Lbl700
ENDIF
IF x <> 0 THEN
x = 0
GOTO _Lbl700
ENDIF
_Lbl1030:
ne=((n(c)-c)/7)*20+30
m=c*20-9
LINE (m - 5, ne - 5)-(m + 5, ne + 5), 1, BF
s(n(c)) = 5
n(c) = n(c) - 7
IF f<>0 THEN
m1$="I Win! haha! Press any key."
GOSUB _Lbl2130
FOR noise1 = 1 TO 3 : FOR noise2=1000 TO 4000 STEP 500
SOUND noise2,100 : PAUSE 100
NEXT noise2 : NEXT noise1
s2=s2+1
GOTO _Lbl190
ENDIF
_Lbl1170:
m1$ = "Your Move": GOSUB _Lbl2000
IF g <> 0 THEN
g = 0
GOTO _Lbl190
ENDIF
_Lbl1220:
p = c
LINE (0, 0)-(200, 19), 0, BF
CIRCLE (p*20-9,10),6
_Lbl1250:
K1$ = INKEY$
IF K1$ = "," OR K1$ = "." OR K1$ = "q" THEN GOTO _Lbl1290
IF K1$ = " " THEN GOTO _Lbl1340
GOTO _Lbl1250
_Lbl1290:
IF K1$ = "." AND c < 7 THEN c = c + 1
IF K1$ = "," AND c > 1 THEN c = c - 1
IF K1$ = "q" OR K1$ = "Q" THEN GOTO _Lbl2200
REM
GOTO _Lbl1220
_Lbl1340:
w1 = 0
m=p*20-9
IF (n(c)-c)/7 < 0 THEN GOTO _Lbl1220
CIRCLE (m, ne), 6
s(n(c)) = 1
e = 0
GOSUB _Lbl1520
_Lbl1420:
IF e<>0 THEN
m1$="you win. Press any key."
GOSUB _Lbl2000
SOUND 50,500 : PAUSE 500 : SOUND 30,700
s1=s1+1
PAUSE 2000
GOTO _Lbl190
ENDIF
n(c) = n(c) - 7
GOTO _Lbl520
_Lbl1520:
p=c*20-9
PAUSE 200
LINE (0, 0)-(300, 19), 0, BF
LINE (p - 5, 5)-(p + 5, 15), 1, BF
FOR a = 0 TO 11
t(a) = 0
NEXT a
i = 0
o = n(c)
FOR u = o TO o + 21 STEP 7
IF u > 42 THEN GOTO _Lbl1640
t(i) = t(i) + s(u)
_Lbl1640:
NEXT u
i = i + 1
k = c - 3
IF k < 1 THEN k = 1
FOR a = k TO c + 3
IF a > 4 OR a > c THEN GOTO _Lbl1810
FOR B = a TO a + 3
t(i) = t(i) + s(o - c + B)
NEXT B
i = i + 1
w = o - (c - a) * 8
IF w < 1 OR w > 18 THEN GOTO _Lbl1810
FOR d = 0 TO 3
t(i) = t(i) + s(w)
w = w + 8
NEXT d
i = i + 1
_Lbl1810:
IF a > 7 THEN GOTO _Lbl1900
IF a < 4 OR a < c THEN GOTO _Lbl1900
w = o + (c - a) * 6
IF w < 4 OR w > 21 THEN GOTO _Lbl1900
FOR d = 0 TO 3
t(i) = t(i) + s(w)
w = w + 6
NEXT d
i = i + 1
_Lbl1900:
NEXT a
FOR h = 0 TO i
d = t(h)
IF d = 4 THEN e = 1
IF d = 15 THEN f = c
IF d = 10 THEN z = c
IF d = 3 THEN x = c
IF h <> 0 AND d = 2 THEN y = c
NEXT h
RETURN
_Lbl2000:
a = 0
_Lbl2010:
a = a + 1
IF a > 7 THEN
GOTO _Lbl2110
ELSE
IF s(a) = 0 THEN
a = 0
GOTO _Lbl2130
ENDIF
ENDIF
GOTO _Lbl2010
_Lbl2110:
m1$ = "Its a draw"
g = 1
_Lbl2130:
LOCATE 10,150
PRINT m1$; " ";
IF m = 0 THEN GOTO _Lbl2180
m = 0
GOTO _Lbl2130
_Lbl2180:
IF g <> 0 THEN s3 = s3 + 1
RETURN
_Lbl2200:
CLS
PRINT : PRINT
PRINT TAB(20); "Thanks for playing."
PRINT
PRINT TAB(20); "www.thebackshed.com"
END
James_From_Canb
Posted: 08:08pm 04 Jan 2013
Glenn,
There's an entry on the Microbee Software Preservation Project site that includes a comment about Connect Four. You need a login for the site. It's at link.
It looks like one version was written for the Microvision handheld by Robert Hoffberg, according to this link.
James
