Forum Index : Microcontroller and PC projects : 25 pin break out
vk4tec
Posted: 02:09pm 31 Dec 2012
I need access to the 25 pins on the DuinoMite connector.
I have 25 way headers and ribbon cable.
Is there a gracefull way to make a break out box ?
I need access to +5 GND COM and a few pins for LCD.
I have lots of wires all over the shop at the moment.
- Andrew -
Andrew Rich VK4TEC
www.tech-software.net
MOBI
Posted: 02:58pm 31 Dec 2012
  Andrew said  Is there a gracefull way to make a break out box ?
Well... you could design a pcb with appropriate plug/socket at either end and break out headers in the middle.
Or...use a little black "jiffy" type box with the plug/socket at either end and breaout connectors (leds etc) on say the lid and do a bit of hand wiring. Its a bit of a birds nest but look good when the lid is on and is easy(ish) to alter if need be.
Or....plug the pugs/sockets onto a bread board (need adapter for pin layout) and use plenty of jumpers (yuk)
Its a bit like the orange and the elephants backside - suck it and see..
David M.
David M.
djuqa
Posted: 03:02pm 31 Dec 2012
You could get this board
Test-mite Board
or this one
DonDuino
Rather than re-inventing the wheel
Edited by djuqa 2013-01-02
VK4MU MicroController Units
Posted: 05:32pm 31 Dec 2012
  djuqa said   You could get this board
Test-mite Board
or this one
DonDuino
While everyone is pushing my Mikky boards,
I think this one might suit you best
Donduino PATCH
Posted: 05:34pm 31 Dec 2012
Andrew,
Also Note that the Duinomite (as is the Maximite) is a 26pin header
MickEdited by bigmik 2013-01-02
James_From_Canb
Posted: 06:16pm 31 Dec 2012
I separated all the wires from my ribbon cable and reorganised them so they were in order from 1 to 26 then soldered them to the in-line header pins. I kept the earth and power wires separate and connected them to the outside rails of the breadboard. Then I pushed the header into the edge of my breadboard and marked every fifth one with a marker pen.
I can easily jumper from the connector side of the breadboard to the project side, or to a separate breadboard.
It might not be pretty, but it works, and by putting the wires in order I have a much better chance of jumpering the correct pin.
Edit: Sorry, I just reread your question and see you were asking about making a breakout box. I didn't answer your question.
JamesEdited by James_From_Canb 2013-01-02
Posted: 06:48pm 31 Dec 2012
Hi James,
Yeah that will work too.. As you say a bit messy but it is for proto bread boarding..
You could use a Test-A-Mite and put male pins facing down where the CGMMStick1 header is (30pin strip shown with a female facing up in the photos) then these male pins can be pressed into the proto PCB and you would have effectively a CGMMStick1 pinout.
