Forum Index : Microcontroller and PC projects : Game problem
rambo55
Posted: 09:33am 23 Dec 2012
I have a colour maximite trying to run old Invaders game I have the joystick connect to maximite run the game press fire button everything is ok for about one sec and this what happen on the screen
463 4720 if Invaders (1 , m) <> 121 Then Invline (1) = Invline (1) +1
Error; Incorrect Expression Syntax
I am new to this maximite program and it will take some time for me to understand as I have only program some on the C64.
Posted: 10:37am 23 Dec 2012
It could be because there is a space after Invline - both times that it is used.
rambo55
Posted: 11:03am 23 Dec 2012
  rambo55 said   I have a colour maximite trying to run old Invaders game I have the joystick connect to maximite run the game press fire button everything is ok for about one sec and this what happen on the screen
I have try everything and space still the same
darthmite
Posted: 12:16pm 23 Dec 2012
Here is the last version i made for maximite v2.x
2012-12-23_220725_Space_Invaders.zip
Now you said you have a colour maximite ... hmmm
Colour maximite use other resolution , the old with line number and B/W was
made for PAL Video output.
For made it easier for you if the last computer you have program was the C64,
just get the example library on the Geoff page and test the program/game made
for the colour Maximite.
And it will be good to not made duplicate post about the same program or game
i refer here at this one : invaders button
Cheers.
BobD
  Geoffg said   It could be because there is a space after Invline - both times that it is used.
also a space after the word Invaders. That won't help either.
Posted: 12:19pm 23 Dec 2012
There is a space between Invaders and ( .
There are also spaces between the two Invline and (
Remove these spaces and give it a try.
I don't have a copy of the version of Invaders that you are using to test it here.
The latest version is without line numbers but it also has an extra space in a similar place (line 471)
