Forum Index : Microcontroller and PC projects : Color Maximite Problem
TASMA
Posted: 09:52am 22 Dec 2012
My Colour Maximite when powered up is in bootload mode, power light flashing, if I reload the hex file it comes back to normal, but next time I power up I have the same problem. I have to re-install hex file everytime I turn it on. How do I fix this?
Brian
CircuitGizmos
Posted: 10:00am 22 Dec 2012
The bootload line that goes to the processor - processor pin 73 - should be at 3.3V for normal operation and 0V for bootload operation.
On the CGCOLORMAX1 I used an external resistor (10k) to make sure that this pin is pulled high (to 3.3V).
Posted: 10:20am 22 Dec 2012
what sort of CMM is it (Altronics kit, UBW32, etc)?
TASMA
Posted: 10:35am 22 Dec 2012
The CMM is an Altronics kit, it worked ok when first assembled
Posted: 12:24pm 22 Dec 2012
My first guess is a leaky 'load firmware' push button.
If so, the external 10k resistor as used by CircuitGizmos would probably help.
It may also be something to do with power supply rails slow to stabilize.
What happens if you do a quick power off then on again without going through the reprogramming?
TASMA
Posted: 01:05pm 22 Dec 2012
I found that cycling the power it eventually came good. Connected a 10k resistor as suggested and all working OK again.
Thanks everyone for your help
Brian
