Forum Index : Microcontroller and PC projects : How cheap can SD cards get?
Posted: 11:39pm 14 Dec 2012
I just bought two 4GB micro SD cards for $5 each. It was just a normal retailer and I originally wanted 2GB but they did not have them as that was "too small".
How cheap is that? Soon we could find them in our cornflakes!
One came with a full sized SD card adapter but the other came with a neat USB adapter, slip the micro SD card into the adapter and you can read it on any PC! $5 each!
I can remember when 5 1⁄4-inch floppies cost $5 and they held 360K... mutter, mutter.
OA47
Posted: 12:48am 15 Dec 2012
Geoff, remember the days when we purchased singled sided floppy disks (as they were cheaper) and felt rewarded when with the use of the hole punch could double the capacity?
IRRC the term was "making flippies from floppies"
Ahhh the good old days
Posted: 12:55am 15 Dec 2012
Yes, and amazingly they were just as good as the "official" double sided floppies.
I should confess, I started on 8 inch single sided single density floppies. A whole 240KB... wow!
OA47
Posted: 01:02am 15 Dec 2012
Yes me too. But I think they were an amazing 180 Kb capacity
Posted: 03:01am 15 Dec 2012
You might be right, it was a long time ago...
CircuitGizmos
Posted: 04:05am 15 Dec 2012
When I started binary there weren't any ones. All I got were zeros.
Posted: 04:31am 15 Dec 2012
Wow, what fantastic bargains!
Unfortunately I predate floppy disks and can recall being really delighted when such wonderful devices first arrived :(
MOBI
Posted: 11:41am 15 Dec 2012
I have about 400 5.25 floppies with many games, programming languages and general data that I can no longer access (no disk drive).
My data storage was a modified cassette deck where I fed the data -5 0 +5 direct to the record/play head and then read it back through an op amp/transistor based schmitt trigger to recover the data. All ran at 1200bps, so now I have a box of cassettes that I also can't acces (somewhere along the line the tape recorder got too rusty and worn to use. the processor was a MC6800 running at 1MHz
I started with 512bytes of ram and when the 2102 (1k x 1 bit) came out I had a whopping 1k of ram in only 8 chips! Wrote a small interpreter language that fitted into 256bytes!!
Those were the days my friend ....sigh....
david m.
David M.
Posted: 12:28pm 15 Dec 2012
  Geoffg said   Yes, and amazingly they were just as good as the "official" double sided floppies.
I admit to being that old too,
My first floppies were 5.25" 68k Single sided 35 track TRS80..
Then I went for 5.25" Double sided, double density, 80 track, which we could bastardise to 85 track and get some massive storage of which I cant remember but around the 1.4Meg using LDOS as the operating system.
I also had 8" on a CPM system and I remember the single sided was about 185kb
EDIT ***
Oh and my first single sided (or maybe double sided) 40 track Floppy drives were MPI brand, bare drives, no case or power supply and cost me $400 each and I only got them that cheap because I bought 4 of them... 40track gave about 80kb
MickEdited by bigmik 2012-12-16
shoebuckle
Posted: 08:07pm 15 Dec 2012
I too predate floppies by interfacing an audio tape recorder to Jim Rowe's Educ8 computer, with all of 256 bytes of memory!
Hugh
James_From_Canb
Posted: 08:38pm 15 Dec 2012
  MOBI said   I have about 400 5.25 floppies with many games, programming languages and general data that I can no longer access (no disk drive).
david m.
I ended up converting my floppies to images and they all fitted on a single CD. I've never looked at them since, but they're there just in case.
I'd suggest contacting your local computer club to see if they have kept a machine with a functioning 5.25" drive and borrow it for long enough to convert the disks. Then get rid of them.
There's no USB 5.25" drives that I can find with a quick check of Google, although there's an interface that might still be available. You still need the drive of course. An old machine's more convenient as it's ready to go.
James
djuqa
Posted: 10:03pm 15 Dec 2012
I found this USB - FDD adaptor board
Very interesting final line of the description
[quote]High quality immersion gold coated boards produced in cooperation with, and assembled by, Olimex Ltd.[/quote]
I have several old, but good condition PC's. I should rebuild one as FDD - USB - SD transfer machine.
Edited by djuqa 2012-12-17
VK4MU MicroController Units
Georgen
Posted: 12:08am 16 Dec 2012
Not SD Card, but USB stick, it is 32GB for $25 at K-Mart now.
George
MOBI
Posted: 12:53am 16 Dec 2012
[quote=james]I'd suggest contacting your local computer club to see if they have kept a machine with a functioning 5.25" drive [/quote]
I spent a couple of years trying to get others in my district interested in electronics with not a murmur of interest. I've not much chance in asking a local computer group. That's a problem with country towns.
d.m.
David M.
paceman
Posted: 02:42am 19 Dec 2012
  Geoffg said   I just bought two 4GB micro SD cards for $5 each. It was just a normal retailer and I originally wanted 2GB but they did not have them as that was "too small".
Hi Geoff,
Where did you get these from? My notebook (old XP) has a card reader that reads/writes the older 1.6mm thick standard MMC cards (MMC-16M) OK but won't read/write the newer SDHC or micro SD adapters because they're too thick at 2.15mm to fit into the slot. Either of these types are OK in the Maximites but the older ones are not that easy to find now and I'd rather not have another stand-alone reader attached to the notebook. The ones you found with the USB connector sounds just the ticket.
Greg
Posted: 03:52am 19 Dec 2012
They came from a Perth computer shop called PLE Computers.
OA47
Posted: 07:56pm 27 Dec 2012
Speaking of old magnetic media. I still have some cassettes with basic programs on them written IIRC at 1200 baud. Does any one have any ideas about using the mite to read this data via a tape deck and the audio port?
