Forum Index : Microcontroller and PC projects : less than greater than
heppy36
Posted: 11:30pm 06 Dec 2012
Hi its probably been asked before (sorry)
can you use > < in a statment
like
if pin(2) > 3 < 2.5 then
Print
else if pin(2) >2.5 < 2 then
print
and so on?
Thanks Martin
Heppy
paceman
Posted: 01:30am 07 Dec 2012
  heppy36 said   Hi its probably been asked before (sorry)
like
Print
print
Heppy,
Not like that - you have to state each test separately and use the logical operators like AND, OR, NOT etc. For example:
If pin(2)> 3 <2.5 then.........has to be stated:
If pin(2)> 3 OR pin(2) <2.5 then......in this case obviously an AND is impossible.
Greg
Posted: 02:56am 07 Dec 2012
[quote]
[/quote]
this could however still give a problem. :)
A problem that can hide itself for years, but of course it will show itself when you least expect it.
When reading a pin value you should save it in a variable before doing multiple tests on it.
Because in the time between the test for (pin(2) > 2) and the next test (pin(2) < 2.5) the value of that pin can change.
Analog values can be interpreted wrong that way.
In the example above the first time pin(2) can return a value of 2 and the next value of pin(2) can be 3 causing the test to be false.
If pin(2) is stored in a variable first then the value of 2 would evaluate to a true.
With a digital input it only flips between 0 and 1 but it can be a disaster when that 0 or 1 will activate something else that really shouldn't.
Best practice:
Only compare variables with other variables or literals/constants
These bugs can be very sneaky especially when the code has been revised.
You can start with:
if pin(2) = 3 then....
and later decide to add a:
if pin(2) = 4 then ....
only to discover at some moment that the code is not doing what you want.
Therefore better to do this:
Value = pin(2)
if Value = 3 then .....
Later you would probably add:
if Value = 4 then ....
Assigning the value to a variable before helps to prevent bugs.
Edited by TZAdvantage 2012-12-08
Posted: 09:44am 07 Dec 2012
like
Print
print
and so on?
Thanks Martin
Rather than doing two tests for each condition, if they can be 'stacked up' correctly you may be able to use one '>' for each.
This is the wind direction sub from my weather station program.
(The resistors used in the sensor make the wind direction voltages jump all over the place!)
_windBrg:
rwm=pin(2)
IF rwm>3.10 THEN
w= 17
ELSEIF rwm > 2.98 THEN : w = 12 'W
ELSEIF rwm > 2.81 THEN : w = 14 'NW
ELSEIF rwm > 2.73 THEN : w = 13
ELSEIF rwm > 2.60 THEN : w = 16 'N
ELSEIF rwm > 2.40 THEN : w = 15
ELSEIF rwm > 2.25 THEN : w = 10 'SW
ELSEIF rwm > 2.00 THEN : w = 11
ELSEIF rwm > 1.70 THEN : w = 2 'NE
ELSEIF rwm > 1.40 THEN : w = 1
ELSEIF rwm > 1.10 THEN : w = 8 'S
ELSEIF rwm > 0.90 THEN : w = 9
ELSEIF rwm > 0.70 THEN : w = 6 'SE
ELSEIF rwm > 0.50 THEN : w = 7
ELSEIF rwm > 0.40 THEN : w = 4 'E
ELSEIF rwm > 0.35 THEN : w = 3
ELSE
w = 5
ENDIF
return
The closest thing to a 'select case' function.
paceman
Posted: 01:57pm 07 Dec 2012
Hi TZ & TassyJim,
Hmm - yes, very true and I think I should have known that from a correction that James (Deakin) made for me on some code a couple of months ago (guess I get a fail there James!)
Greg
