Forum Index : Microcontroller and PC projects : Cgcolormaxi memory
Bill.b
Posted: 07:53pm 01 Dec 2012
Just received my Cgcolormaxi and tryed to run
Nick's maxman
Error generated :-
70 Font Load "Screen,fnt" as #5:Font #5:c=97
Error Not enough memory.
any help would be apreciated.
Nick
Posted: 08:12pm 01 Dec 2012
I should be recieving my Color Maximite this week so I can test it with my Max-Man.
But, I think the problem may be that the Colormax boots in an 8 colour mode which utilizes more memory, hence Max-man (which was tight already) runs out of RAM.
The fix possibly is to add a line to the Max-Man BASIC code at the start to set the Colormax to a b/w mode the same as the original Maximite.
Nick
Bill.b
Posted: 08:44pm 01 Dec 2012
Thanks Nick. I will give it a go and seen what happens.
Bill.b
Posted: 09:00pm 01 Dec 2012
I set the Mode command to Mode 1
max-man worked OK
BillEdited by Bill.b 2012-12-03
sinclair67
Posted: 09:16pm 06 Dec 2012
I would become recieving my Color Maximite immediately in order to test that together with my Max-Man.
However, I do believe the challenge could be how the Colormax shoes or boots in the 8 color setting which usually uses far more memory, therefore Max-man (which was tight already) runs out of RAM.
The particular correct quite possibly is to give a line on the Max-Man Simple signal from the beginning setting the Colormax with a b/w mode the same as the unique Maximite.
Each game is detailed with cost,
gw2 key
Cheap RS Gold
Posted: 03:21pm 07 Dec 2012
Hi Sinclair,
I am sorry I am not quite sure what you are trying to get at above...
Yes the CMM has less available memory due to the colors but I am not sure what you are proposing.
Are you suggesting adding a line to MaxMan to set the BW mode?
Bill.b
Posted: 06:37pm 07 Dec 2012
Hi Mick
I added the command 'MODE 1' to the start of the maxman program.
It ran OK on my Colour maxi.
