Forum Index : Microcontroller and PC projects : Satellite location software
Posted: 04:00pm 26 Nov 2012
One of the first tasks when I pull up at a new campsite is to set up the satellite TV.
There are lots of sources of pointing data available but some need Internet access, some don’t take into account the 45 degree tilt of the Optus satellites and at least one printed table from a major supplier has incorrect data.
As I was installing a Maximite in the caravan to monitor various systems, the Maximite was an obvious choice for a satellite aiming program.
To run the program, you will need the attached data file in the current working directory.
The program is set up for Australia but it would not be too difficult to adapt for anywhere.
The biggest task would be getting the magnetic variation table.
' geostationary satellite pointing
' by TassyJim 27 Nov 2012
' based on Nomads Alamnac www.c-com.com.au/nomad.htm
' formula from an old edition of the ARRL Handbook
satC1Long=156 ' position of the satellite of interest
fromFront=1 ' for skew, we are looking at the front of the dish
dim magdev$(36) ' magnetic variation table storage
' 46 degrees of longitude at 5 bytes each gives a string 230 bytes long.
' one string for each of 36 degrees of latitude
open "magdev.txt" for input as #1
for n = 1 to 36
input #1,magdev$(n)
next n
input "Latitude ";lat1
input "Longitude ";lon1
if lat1=0 then lat1= -41.1258 ' default location
if lon1=0 then lon1= 145.9078 ' we could be getting this from a GPS
cls
if mm.device$ <> "" then font 2,1 ' don't try to set the font for DOS MMBasic
print " Optus C1 bearing from "
print " ";lat1;" ";lon1
magDev=deviation(lat1,lon1)
print
print " Magnetic Variation:";format$(magDev,"% 5.1f")
dishAZ= azimuth(satC1Long,lat1,lon1)
print " Azimuth (True): ";format$(dishAZ,"% 5.1f")
dishAZmag=dishAZ-magDev
if dishAZmag < 0 then dishAZmag=dishAZmag+360
print " Azimuth (Magnetic):"format$(dishAZmag,"% 5.1f")
dishEL= elevation(satC1Long,lat1,lon1)
print " Dish Elevation: ";format$(dishEL,"% 5.1f")
dishSK= tilt(satC1Long,lat1,lon1)
dishSK=dishSK-45 ' Optus satellite skew
if fromFront=0 then
print " LNB Skew: ";format$(dishSK,"% 5.1f")
print
print " Skew is clockwise looking at Sat."
else
print " LNB Skew: ";format$(dishSK* -1,"% 5.1f")
print
print " Skew is clockwise looking at dish"
endif
end
function azimuth(satlong,eslat,eslong)
longdiffr=(eslong-satlong)/57.29578
esazimuth=180+57.29578*atn(tan(longdiffr)/sin((eslat/57.2957 8)))
if eslat<0 then esazimuth=esazimuth-180
if esazimuth<0 then esazimuth=esazimuth+360.0
azimuth = esazimuth
end function
function elevation(satlong,eslat,eslong)
eslatr=eslat/57.29578
r1=1+35786/6378.16
v1=r1*cos(eslatr)*cos(longdiffr)-1
v2=r1*sqr(1 - cos(eslatr)*cos(eslatr)*cos(longdiffr)*cos(longdiffr))
eselevation=57.29578*atn(v1/v2)
if eselevation < 30 then
eselrefracted=(eselevation+sqr(eselevation*eselevation+4.132 ))/2
else
eselrefracted=eselevation
endif
if eselrefracted < 1 then eselrefracted=0
elevation= eselrefracted
end function
function tilt(satlong,eslat,eslong)
longdiffr=(satlong-eslong)/57.29578
poltilt=-57.29578*atn(sin(longdiffr)/tan(eslatr))
tilt= poltilt
end function
function deviation(lat,long) ' magnetic variation for Australia
latmin=abs(lat) -9 ' our table starts at 10 deg South
longmin= long-109 ' and 110 deg East
if latmin < 1 or longmin < 1 then ' check that we are in range of the table
deviation = 0 ' we could use a better number to indicate
goto _exitfunc ' out of range. eg 99
endif
if latmin > 36 or longmin > 46 then
deviation = 0
goto _exitfunc
endif
latI=int(latmin)
longI=int(longmin)
dev1=val(mid$(magdev$(latI),longI*5-4,5)) ' data is stored in a string
dev2=val(mid$(magdev$(latI),longI*5+1,5)) ' for each degree of latitude
dev3=val(mid$(magdev$(latI+1),longI*5-4,5)) ' we extract the 4 points bounding
dev4=val(mid$(magdev$(latI+1),longI*5+1,5)) ' our position
inclong=dev2-dev1:inclat=dev3-dev1 ' and interpolate for our position
deviation=dev1+inclong*(longmin-longI)+inclat*(latmin-latI)
_exitfunc:
end function
The program and the mag dev data are in the zip file.
2012-11-27_020126_nomad.zip
Jim.
Edited by TassyJim 2012-11-28
Posted: 06:06pm 26 Nov 2012
Wow, that is neat.
Send me an email if ever you get near Perth.
paceman
Posted: 08:28pm 26 Nov 2012
Jim,
What's a good text/source you'd recommend for learning something about setting up satellite TV. I've got a mate who's setting off next year for some SKI'ing round the country and I wouldn't mind building a little Maximite system with something like this for him - maybe with the GPS too. It might even bring back some of the terrestrial navigation course I did about 40 years ago for offshore sailing. That was a waste - the following year they installed radio beacons around Bass Strait. I filed away my Norrie's tables never did a sight or calculation again.
Greg
Posted: 08:58pm 26 Nov 2012
  paceman said
Jim,
Greg
Not what I would call a GOOD source but have a look at Nomad's Almanac.
I wrote it a few years ago when I started doing the grey nomad thing.
http://www.c-com.com.au/nomad.htm
The help file has bit of useful information in it.
The new VAST TV system is a huge improvement over the previous setups.
I can watch ABC TV and Radio from all States wherever we are. Very good for seeing what the local Pollies have been getting up to while we are away.
Geoff,
we were in WA a few years ago and are not sure when we will be heading back.
This year's winter trip was interrupted with a family matter and it might be a while before we can get away for a long trip again.
paceman
Posted: 01:02am 27 Nov 2012
Thanks Jim - I had trouble running it though. I downloaded the setup file, ran it and it installed OK (looked like it did anyway - displayed the icon OK). But when I tried to run it, it threw a "Warning - maximum number of fonts exceeded" and it wouldn't clear. I had to stop it with the Task Mgr - any ideas? I'm running an older XP SP2 notebook.
Greg
Posted: 12:22pm 27 Nov 2012
  paceman said
Thanks Jim - I had trouble running it though. , it threw a "Warning - maximum number of fonts exceeded" and it wouldn't clear.
Greg
I LOVE a new challenge.
Have sent you a PM
isochronic
Posted: 03:25pm 29 Nov 2012
Speaking of satellites - nov 29th is the anniversary
of WRESAT...a small satellite launched by Aus back in 1967
(with generous help from the 'States). The blurb says
it made Aus the fouth country to launch a satellite from its own
land, after USA, USSR, France. Nice !!
