Forum Index : Microcontroller and PC projects : UBW32 A:
Dinosaur
Posted: 01:46pm 25 Nov 2012
Hi All
Just starting a little project to pulse a stepper motor.
Have a UBW32 with nothing attached, and latest image.
Using Tera-Term
Typing commands and running the motor is not a problem,
I have enough programming and Basic experience to do that.
However, when I try to save the program to the flash drive with:
Save "A:Autorun.bas"
or
Save "B:Autorun.bas"
I get:
Error: SD card not found.
Typing:
Print "MM.Drive$"
I get B:
Typing:
Print "MM.Device$"
I get "Colour maximite"
So, at least B: exists, but wont let me save a single line program.
Any hints greatly appreciated.
Hervey Bay Qld.
BobD
Posted: 02:18pm 25 Nov 2012
The drivespec is not part of the Save command. Use the command Drive "A:" and then do a Save with just the filename. Did I read recently in a post from Geoff that the quotation marks were now optional in some of these commands?
BobD
Posted: 02:30pm 25 Nov 2012
I was right about the quotes. It was in the change log for V4.0a.
Change log for MMBasic Ver 4.0A
When using the RUN, SAVE or LOAD commands quote marks are no longer required around
the file name. They are still required if the command is used within a program.
Dinosaur
Posted: 05:10pm 25 Nov 2012
Hi All
Many thanks for that, it solved the issue.
I guess these are the little oddities that are different
from some Basic's
Hervey Bay Qld.
Posted: 09:17pm 25 Nov 2012
  Dinosaur said   Hi All
from some Basic's
That should have worked. It sounds like a bug to me, I will chase it up.
