Forum Index : Microcontroller and PC projects : GPS data logger issues
vk4tec
Posted: 11:56pm 21 Nov 2012
Hello
I have been working on a GPS logger for some months.
I was having good success with LCD and LED displays for data.
I even did some basic TRIG.
I would like to share some observations in the hope someone may be able to help.
I have had problems with
1. Data corruption on the serial line
2. SD card writes after a long period of time.
With the data corruption on the serial line, this shows up as extra charcaters in the NMEA data stream.
I have tried processing character by character and making up a message based on commas and * which identifies the end of a NMEA line.
I have also just recently tried the LINE INPUT command as well.
Here is a sample of what is going on
$GPRMC,234336.000,A,2720.2571,S,15302.5943,E,0.00,183.56,201 112,,,A*70
$GPRMC,234337.000,A,2720.2571,S,15302.5943,E,0.00,183.56,201 112,,,A*71
$GPRMC,234P338.000,A,2720.2571,S,15302.5943,E,0.00,183.56,20 1112,,,A*7E
$GPRMC,234339.000,A,2720.2571,S,15302.5943,E,0.00,183.56,201 112,,,A*7F
$GPRMC,234340.000,A,2720.2571,S,15302.5943,E,0.00,183.56,201 112,,,A*71
See the extra "P" snuck in there somehow.
I tried playing with the serial buffer - did not really help.
Is it too much for the DuinoMite to read NMEA, print to VGA and save to SD ?
I have after about 12 hours, an error and the system stops writing to the SD card.
I have tried opening the file, and leaving it open and just append - I lost a whole lot of data after a power failure - the file was not closed off.
I also tried each NMEA line, writting to the SD card. open append and close.
Am what I am doing a big ask ? I did everything in assembly language besides write to an SD CARD then I went looking and found DuniMite.
The NMEA is from a MOD-GPS at 19200. I have a buffer of serial of 1024.
I am keen to get this stable as it is great solution.
Its just these two odd behaviours I can't explain
The power supply is fine.
I am printing to VGA the NMEA as well
Here is the code, its pretty simple and displays odd charcaters and bombs out on SD card writes now and then
file$ = "GPSLOG.LOG"
Open "COM3:19200,1024" As #1
Line Input #1,msg$
Print msg$
Open file$ For append As #3
Print #3, MSG$
Close #3
Loop
EXT is used - DuinoMite Mini
- Andrew VK4TEC -
Andrew Rich VK4TEC
www.tech-software.net
vk4tec
Posted: 12:04am 22 Nov 2012
Here is the other way I do it
Get character by character from the serial port
file$ = "GPSLOG.LOG" ' initial filename
max =20
Dim arg$(max)
nmea_sentence
'Print msg$
x$ = Input$(1, #1)
msg$ = msg$ + x$
x$ = Input$(1, #1)
msg$ = msg$ + x$
If arg$(0) = "GPRMC" Then
Print msg$
file$ = arg$(9) + ".LOG"
GoTo savefile
EndIf
If arg$(0) = "GPGGA" Then
Print msg$
GoTo savefile
EndIf
Rem save to SD card
GoTo andrew
savefile:
'file$ = arg$(9) + ".LOG"
'Open file$ For append As #3
Print #3, MSG$
'Close #3
andrew:
Loop
Rem -- SUBS --
Sub nmea_sentence
msg$ ="$" ' subroutine start
Do While Input$(1, #1) <> "$" : Loop ' wait for the start
For i = 0 To max
arg$(i) = "" ' clear ready for data
Do ' loops until a specific exit
x$ = Input$(1, #1)
' Print x$
msg$ = msg$ + x$ ' get the character
If x$ = "," Then Exit ' new data field, increment i
If x$ = "*" Then Return ' we have all the data so return
arg$(i) = arg$(i) + x$
'Print arg$(i) ' add to the data
Loop
'Print arg$(i) ' loop back for the next char
Next i ' move to the next data field
' Print "Corrupt data..." ' exceeded max data items
'Print msg$
Loop
End Sub
Andrew Rich VK4TEC
vk4tec
Posted: 01:44am 22 Nov 2012
I have tried something
1. Reduce the GPS rate to 9600
2. Turn off all but $GPRMC and $GPGGA
3. Gone back to the character by character mode
- Andrew -
Andrew Rich VK4TEC
cwilt
Posted: 05:56am 22 Nov 2012
Andrew,
Have you tried a different GPS? I had a Duinomite Mega and a GPS shield from Sparkfun using similar software design running for months without issue.
This is the shield.
Does the error happen at completely random times?
Talbit
Posted: 11:47am 22 Nov 2012
Andrew,
See my article on my GPS clock somewhere under my name. I'm using a Garmin GPS 16HVS running at 19200, 1Hz spitting out $GPRMC only. I haven't spotted any problems. Running at that speed have you got good layout with short interconnecting wires? I'm using the original Maximite with around v3.1 I think.
TalbitEdited by Talbit 2012-11-23
Talbit
vk4tec
Posted: 04:05pm 22 Nov 2012
Got some GPS I can try
GPS18LVC
GPS18 5Hz
GPS72
Speed changes did not make a dif, maybe it is GPS
- Andrew -
Andrew Rich VK4TEC
vk4tec
Posted: 12:24am 23 Nov 2012
Change of pace
Dumped the MOD-GPS
Hooked up GARMIN GPS185Hz
Locked it down to 19200
Locked it down to $GPRMC
So far so good
Maybe GPS was cactus ?
- Andrew -
Andrew Rich VK4TEC
vk4tec
Posted: 11:16am 24 Nov 2012
I have now worked out my GPS issues.
I now need to attend to the SD CARD issue.
After a long time. The program will stop
at open file$ for append as #3
Error: Cannot write to file.
Does that mean the file is not closed off properley ?
Is it too big ?
Is it that I need some pause statements ?
The SD card is written to many times. and quickly.
- Andrew -
Andrew Rich VK4TEC
vk4tec
Posted: 11:29am 24 Nov 2012
Is there such a thing as software commanded reboot ?
A software watchdog timer ?
- Andrew -
Andrew Rich VK4TEC
Posted: 12:45pm 24 Nov 2012
  vk4tec said   Is there such a thing as software commanded reboot ?
- Andrew -
You could always try connecting an unsed ouptut pin (pulled high via a 10k or 4k7 OHM resistor) to the RESET.. when you want to reset the MM direct the pin to go LOW and bingo it kicks itself up the ..... errr ... well it resets itself.
The MM should reconfigure the pin as an INPUT and the pull up would keep it high until the MM has control again.
James_From_Canb
Posted: 02:30am 25 Nov 2012
Are we talking about the code you posted above? That code only opens the file before the main DO statement, which is the first few fractions of a second of processing. You should never get that message a long time after you've started the program.
Would you please post your current code?
James
TinkersALot
Posted: 03:01am 25 Nov 2012
How large is the file when the program quits?
vk4tec
Posted: 11:08am 25 Nov 2012
I think I might have fixed it
Instead of one big file or daily files, I have gone to hourly files.
Has not bombed out yet.
- Andrew -
Andrew Rich VK4TEC
vk4tec
Posted: 11:21am 25 Nov 2012
The files at the moment are about 2 MB
- Andew -
Andrew Rich VK4TEC
Posted: 06:04pm 25 Nov 2012
  vk4tec said   The files at the moment are about 2 MB
- Andew -
Thats Interesting Andrew,
Maybe you have your SD card formatted at FAT12 which has a maximum file size of 32MB (which at 2MB per hr is about 16hrs use..)
If you formatted with FAT16 you can get 2GB files or FAT32 you can get 4GB files..
vk4tec
Posted: 11:25pm 25 Nov 2012
What is odd, is when the program bombs out, I can restart it and it keeps going for a bit more.
Its not as if it reaches a limit and then stops all together
Maybe it is like the variable to write to the card or the offset for the SD card becomes too big.
It sometimes bombs out trying to open, as if it did not close properley.
Well at the moment it has not missed a beat at 2 MB hourly files.
- Andrew -
Andrew Rich VK4TEC
vk4tec
Posted: 11:44pm 25 Nov 2012
Andrew Rich VK4TEC
Posted: 01:36am 26 Nov 2012
  vk4tec said   What is odd, is when the program bombs out, I can restart it and it keeps going for a bit more.
- Andrew -
How about compressing/filtering the data. That would save a good amount of data.
An entry i save is like this:
Timestamp,longitude,latitude,direction,speed
some real data:
19f2wq,4.516478,51.812278,N,0
The timestamp is compressed by using an offset and base64 coding of the timestamp.
It is about 32 bytes on average.
If you have 1 per second an hour would be about 32 * 60 * 60 = 115200 bytes.
You can have about 17 hours worth of data in that 2 MB.
I found for vehicle tracking once a minute is sufficient while driving and every 15 minutes while parked.
It is really a datasaver. A vehicle transmitting that data over GPRS is on average 1.2MB for a month!
All application differ but they do have in common to find out what data is really needed, not what is available as that often is just too much and can slow down the processing of that data a lot.
Edited by TZAdvantage 2012-11-27
