Local Time 06:44 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Maximite Basic for the Raspberry PI?
aargee
Posted: 11:56am 14 Nov 2012
Geoff,
This might be quite difficult, but seeing how you've got a DOS version, how hard would MM Basic on the Raspberry Pi be? It would be a killer application!!
- Rob.
vasi
Posted: 12:47pm 14 Nov 2012
Options for BASIC language in linux:
1. http://www.basic256.org/index_en
2. http://sourceforge.net/projects/sdlbasic/
3. http://www.bwbasic.at/info.htm
4. http://gambas.sourceforge.net/en/main.html VisualBasic approach
- probably others...
MMBasic for DOS can be run in Linux with DOSBox (full screen if you want) emulator. All these can be found in an Ubuntu repository. Of course, don't know if all are available (should be, considering the target of rPI) for Raspberry PI...
Edited by vasi 2012-11-15
Elvish name: Mablung Miriel
Beyound Arduino Lang
