Local Time 06:44 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : (DM) More Outputs with decoder?
mariae71
Posted: 09:58pm 10 Nov 2012
I was thinking...
Would it be possible to connect a MM74HC4514 (or similar 4-to-16 decoder) to 4 pins on the DuinoMite and get 16 outputs by setting the 4 pins in binary code? Or have I misunderstand the function of that chip?
2 x DuinoMite Mega
1 x DuinoMite eMega
Posted: 10:34pm 10 Nov 2012
That would give you ONE output high at a time.
Is that that is what you are after?
JimEdited by TassyJim 2012-11-12
Posted: 10:35pm 10 Nov 2012
With that chip you will be able to switch on only one of the 16 pins at a time.
Great if that is what you need.
mariae71
Posted: 10:40pm 10 Nov 2012
Thanks! English is not my native language, but does not "latch" imply that that chip hold the state? So i can set one pin of the chip, and then set another and the first pin is still set until i unset it? Edited by mariae71 2012-11-12
2 x DuinoMite Mega
1 x DuinoMite eMega
Posted: 10:51pm 10 Nov 2012
It will latch the 4 bits.
The 4 bits internally will then not change when the data on the input is removed.
The single output selected by those 4 bits will stay high until the next time a 4 bit value is 'latched'.
You can think of a latch as a small memory.
mariae71
Posted: 10:55pm 10 Nov 2012
Ah! Oki, then it's not what I'm after... Thanks... :)
2 x DuinoMite Mega
1 x DuinoMite eMega
Posted: 11:16pm 10 Nov 2012
  mariae71 said   Ah! Oki, then it's not what I'm after... Thanks... :)
Hi Oki,
Maybe it would be easier to help you if you explain EXACTLY what you need fr your project..
How many outputs?
How many inputs?
Individually on/off or either/or outputs?
It might end up cheaper with 2 duinomites talking to each other...Or there are simple i/o expander chips avail as well.
Please provide a bit more detail.
mariae71
Posted: 11:28pm 10 Nov 2012
Hi Oki,
How many outputs?
How many inputs?
Ah! Sorry... I don't have any current application/requirement for more outputs, I was just planning ahead for a possible NC table I'm thinking about making (planning to print the coordinates on LCDs and they steal a lot of output pins)... But what little I have thought about it 10 extra outputs would be a luxury... I do have another DuinoMite Mega and a DuinoMite eMega lying around, so the option with getting a couple of them to talk to each other is a really good option...
2 x DuinoMite Mega
1 x DuinoMite eMega
BobD
Posted: 11:41pm 10 Nov 2012
You could use one (or 8) of these to get some extra I/O pins. 8 ports on up to 8 chips all on an I2C bus.
PCF8574 Remote 8-bit I/O expander for I2C-bus.
2012-11-11_093826_PCF8574_data_sheet.pdf
Hi Oki,
Of course you could program the duinomite with DMBasic and have a full 20 io pins but you would need to use line numbered code...
MickEdited by bigmik 2012-11-12
CircuitGizmos
Posted: 06:40am 11 Nov 2012
  BobD said   You could use one (or 8) of these to get some extra I/O pins. 8 ports on up to 8 chips all on an I2C bus.
Use of a PCF8574 is described in the Beginning Maximite document.
BobD
Posted: 09:01am 11 Nov 2012
I like the application but it needs the voice too and that would be huge. Next version please CG. Gotta get out the old dvds tonight.
CircuitGizmos
Posted: 12:30pm 11 Nov 2012
I would say "By your command" if I had a mod file that said 'by your command'...
Posted: 01:20pm 11 Nov 2012
  CircuitGizmos said   I would say "By your command" if I had a mod file that said 'by your command'...
Here a WAV file for you if you can convert it
By Your Command
mariae71
Posted: 01:28pm 11 Nov 2012
Thank you very much guys, this seems to be a very nice solution. :)
2 x DuinoMite Mega
1 x DuinoMite eMega
mariae71
Posted: 02:06pm 11 Nov 2012
By Your Command
That particular sample was corrupted somehow, but i found another one and made a mod file with Milky Tracker:
2012-11-12_000630_By_your_Command.mod.zip
edit: Pitch was wrong and sound to quiet... New version 2012-11-12_001729_By_your_Command.mod.zipEdited by mariae71 2012-11-13
2 x DuinoMite Mega
1 x DuinoMite eMega
jman
Posted: 02:22pm 11 Nov 2012
Take look at this post
PCF8574
mariae71
Posted: 02:45pm 11 Nov 2012
  jman said   Take look at this post
PCF8574
That's very elegant! Thanks! :)
2 x DuinoMite Mega
1 x DuinoMite eMega
CircuitGizmos
Posted: 03:14pm 11 Nov 2012
PCF8574
Excellent solution!
CircuitGizmos
Posted: 03:25pm 11 Nov 2012
By Your Command
Played on my PC but didn't play on the ColorMax.
