Local Time 06:43 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 7 segment displays
palcal
Posted: 07:35pm 08 Nov 2012
I have a program that outputs to an LCD display but it is not readable at a distance so I want to use 7 segment displays. I have done this before some years ago, and remember that I loaded a Hex number into the RA, RB port etc to set the bits to display the wanted number on the display. Is there a way to do this in MM basic or do I have to use the 'pin' command to set each one individually.
I havn't done much programming for the last 20 years and am a bit rusty, and things have changed, so please bare with me.
Palcal.
MM_Wombat
Posted: 09:34pm 08 Nov 2012
PalCal,
How do you send commands to the lcd display, spi, or i2c?
If you are using spi then you can connect a 74HC595 shift register chip via the spi, with its outputs sent to the seven segment display unit. You will need a 74HC595 for each unit in the display bank. You feed the output from the first 74hc595 to the second chips input, and so on as you daisy chain the display together. Then to activate a certain character, you send the bitwise command to the display via spi. If you have 4, 7 segment displays, then you need to send 4 commands. I usually just resend the entire 4 characters...
Backshed Previous thread about 74hc595
I also use a couple of DMD panels from freetronics. 16 leds high x 32 leds wide, spaced 10 mm apart(16cmx32cm) with a command added to the source v3.2, working on a v4.0 version, that mirrors the vga display to the panel, in under a few milliseconds.
Regards MM_Wombat
Keep plugging away, it is fun learning
But can be expensive (if you keep blowing things up).
Maximite, ColourMaximite, MM+
palcal
Posted: 11:07am 09 Nov 2012
I have the hardware already built. I'm using 70mm displays so have to run them from 12v. using transistors. I have 6 displays so have seven lines for the anodes and six for the cathodes to switch the segments on and off. At the moment I'm using the routine from the MM library to run an LCD.
To program the ten numbers will take 7 instructions per number. I remember in assembler I could just load $3F into port B and I would have a zero, or in Picbasic I could use a lookup table and 'Poke PortB,$3F'.
I was just wondering if there was an easier way in MM basic other than programming pin by pin.
Palcal.
CircuitGizmos
Posted: 11:20am 09 Nov 2012
Nothing in MMBasic for 8-bit port control.
Make a subroutine for that.
BobD
Posted: 07:04pm 09 Nov 2012
If you could manage to put a bit more hardware between your displays and the MM you could have an easier time getting it going. There are chips around that can interface with SPI to the Maximite and can be loaded with what you wish to display, what brightness & decimal point. Once you do that the MM can go away and do other things. Have a look at these links.
http://www.maximintegrated.com/datasheet/index.mvp/id/1339
http://www.maximintegrated.com/datasheet/index.mvp/id/3195
palcal
Posted: 09:53pm 09 Nov 2012
Thanks for the help don't know about the MAX------ chips though, my large displays have 4 LEDs per segment and need to run off 12v. I will look into it.
Palcal.
Posted: 10:00pm 09 Nov 2012
There is not a command to output 8 bits at once.
The best way to do what you want in software is to create a subroutine similar to the sub LCD_Nibble() in LCD.BAS in the MM Library. That way you have the convenience of a single call to output the data.
Inside the sub you would have a series of commands to set each pin but that is not really an issue when you look at it. If there were eight pins to set and it took about 30uS for each command, the overall time to output the byte would be 0.25mS. Fast enough for your purpose.
palcal
Posted: 12:39pm 10 Nov 2012
Thanks Geoff, I will go that way.
Palcal.
mariae71
Posted: 06:47pm 10 Nov 2012
I recently hooked up some 7 segment displays to my DuinoMite, used a 4026B that has a decade counter with 7-segment display driver, that chip only needs two pins per display from the microcontroller, count and reset (plus gnd ofcourse).
2 x DuinoMite Mega
1 x DuinoMite eMega
Posted: 08:54pm 10 Nov 2012
Personally i like I2C devices for this application and a good chip to suit is the SAA1064.
data sheet.........
2012-11-11_065348_SAA1064.pdf
Pete.
Talbit
Posted: 05:37pm 13 Nov 2012
BobD,
Have you made up a test circuit using the MAX chips and driving it with SPI. I'd be keen to see your efforts if you have.
Talbit
Talbit
BobD
Posted: 06:57pm 13 Nov 2012
  Talbit said   BobD,
Talbit
No I haven't. I was looking for a seven segment decoder some time back and I thought what a useful chip it could be. I was looking to drive multiple 7 segments. I never did it. Well, not so far. The other way of doing what you want could be to use the PCF8574 as found by jman in another post here.
You would need one for each 7 seg display and you just plug them together. Each one is individually addressable.Edited by BobD 2012-11-15
MM_Wombat
Posted: 11:14pm 15 Nov 2012
I used the AS1107 chip from Austria Micro systems, which controls 8 seven segment displays or 1 8x8 led matrix. I used the spi interface to display scrolling characters on three 8x8 displays. A video is available for viewing HERE ..
Video file is 47.4 Mb..
And my code..
mytext$=" Maximite by Geoff Graham, MMBasic V3.2 . Program by Dennis Wyatt."
SetPin 18, 2 'set rx pin AS a digital input
SetPin 19, 8 'set tx pin AS an output
Pin(20) = 1 : SetPin 20, 8 ' set clk pin high THEN set it AS an output
Pin(17) = 1 : SetPin 17, 8 'pin 17 will be used AS the enable signal
Cls
hex1 = 0 : test1 = 0
Option base 0
Dim blink(3) : blink(0)=160 : blink(1)=176 : blink(2)=144
blinker=0
pausetime=51
Dim bcodeHEX(2) : bcodeHEX(0)=0 : bcodehex(1)=4
Dim displaydigit0(1500) ' 250 Characters 6 column wide
Dim characters(96,5)
GoSub dataread
GoSub builddisplaydata
leadingzeroes$="000000000000"
'setup chips
temp1=&H0900 ' no decode mode
temp2=temp1
temp3=temp1
GoSub senddata
temp1=&H0b07 ' scan limit
temp2=temp1
temp3=temp1
GoSub senddata
temp1=&H0A04 'intensity global
temp2=temp1
temp3=temp1
GoSub senddata
temp1=&H0C81 ' wake up
temp2=temp1
temp3=temp1
GoSub senddata
text$=Inkey$
If text$="3" Then 'test display
test1=Not test1
temp1=&H0F00 + test1
temp2=temp1
temp3=temp1
GoSub senddata
EndIf
If text$="8" Or text$="q" Then 'shutdown
temp1=&H0C80
temp2=temp1
temp3=temp1
GoSub senddata
If text$="q" Then End
EndIf
If text$="b" Then 'blink
blinker=(blinker + 1) Mod 3
GoSub buildfeature
temp2=temp1
temp3=temp1
GoSub senddata
EndIf
'write all digits then increment textpos to scroll text
temp1=&H0100+displaydigit0(textpos Mod scrollcount)
temp2=&H0100+displaydigit0((textpos+8) Mod scrollcount)
temp3=&H0100+displaydigit0((textpos+16) Mod scrollcount)
GoSub senddata
temp1=&H0200+displaydigit0((textpos+1) Mod scrollcount)
temp2=&H0200+displaydigit0((textpos+9) Mod scrollcount)
temp3=&H0200+displaydigit0((textpos+17) Mod scrollcount)
GoSub senddata
temp1=&H0300+displaydigit0((textpos+2) Mod scrollcount)
temp2=&H0300+displaydigit0((textpos+10) Mod scrollcount)
temp3=&H0300+displaydigit0((textpos+18) Mod scrollcount)
GoSub senddata
temp1=&H0400+displaydigit0((textpos+3) Mod scrollcount)
temp2=&H0400+displaydigit0((textpos+11) Mod scrollcount)
temp3=&H0400+displaydigit0((textpos+19) Mod scrollcount)
GoSub senddata
temp1=&H0500+displaydigit0((textpos+4) Mod scrollcount)
temp2=&H0500+displaydigit0((textpos+12) Mod scrollcount)
temp3=&H0500+displaydigit0((textpos+20) Mod scrollcount)
GoSub senddata
temp1=&H0600+displaydigit0((textpos+5) Mod scrollcount)
temp2=&H0600+displaydigit0((textpos+13) Mod scrollcount)
temp3=&H0600+displaydigit0((textpos+21) Mod scrollcount)
GoSub senddata
temp1=&H0700+displaydigit0((textpos+6) Mod scrollcount)
temp2=&H0700+displaydigit0((textpos+14) Mod scrollcount)
temp3=&H0700+displaydigit0((textpos+22) Mod scrollcount)
GoSub senddata
temp1=&H0800+displaydigit0((textpos+7) Mod scrollcount)
temp2=&H0800+displaydigit0((textpos+15) Mod scrollcount)
temp3=&H0800+displaydigit0((textpos+23) Mod scrollcount)
GoSub senddata
textpos=textpos+1
' If textpos =65000 Then textpos=textpos-65000
Pause pausetime
If text$="i" Then
Print "Please enclose in quotes, for punctuation to be displayed"
Input "Enter text "; mytext$
Print Len(mytext$)
EndIf
If text$="p" Then
pausetime = (pausetime +10) Mod 200
Print pausetime
EndIf
Loop
senddata:
' rem
Pin(17) = 0 'assert the enable line (active low)
Timer = 0
junk1 = SPI(18, 19, 20, temp3, H, 0, 16) 'send the command
junk1 = SPI(18, 19, 20, temp2, H, 0, 16) 'send the command
junk1 = SPI(18, 19, 20, temp1, H, 0, 16) 'send the command
tempcount=(tempcount+1) Mod 256
junk2 = SPI(18,19,20,tempcount,H,0,8)
Pin(17) = 1 'deselect the slave
' duration=Timer
' datasent1=temp1: datareturned1 = junk1
' temp = temp1 : junk = junk1
' datasent=temp : datareturned=junk
' zerotemp$= Right$(leadingzeroes$,16-Len(Bin$(temp)))
' zerojunk$= Right$(leadingzeroes$,16-Len(Bin$(junk)))
' Print " "; zerotemp$+Bin$(temp)
' Print
' Print " "; zerojunk$+Bin$(junk)
' Print
' Print "Duration = ";duration;" mS"
' Print Hex$(datasent);",";Hex$(datareturned)
' Print "-------------------------"
Return
buildFeature:
temp1=&H0E00
temp1= temp1 Or bcodehex(hex1)
temp1= temp1 Or blink(blinker)
Return
Dataread:
For i= 0 To 95
For j= 0 To 4
Read a
characters(i,j)= a
Next j
Next i
Return
Data &b00000000, &b00000000, &b00000000, &b00000000, &b00000000 ' space
Data &b00000000, &b00000000, &b01111001, &b00000000, &b00000000 ' exclamation_mark
Data &b00000000, &b01110000, &b00000000, &b01110000, &b00000000 ' double_quotes
Data &b00010100, &b01111111, &b00010100, &b01111111, &b00010100 ' hash
Data &b00010010, &b00101010, &b01111111, &b00101010, &b00100100 ' dollar_sign
Data &b01100010, &b01100100, &b00001000, &b00010011, &b00100011 ' percent
Data &b00110110, &b01001001, &b01010101, &b00100010, &b00000101 ' ampersand
Data &b00000000, &b01010000, &b01100000, &b00000000, &b00000000 ' apostrophe
Data &b00000000, &b00011100, &b00100010, &b01000001, &b00000000 ' left_parenthesis
Data &b00000000, &b01000001, &b00100010, &b00011100, &b00000000 ' right_parenthesis
Data &b00010100, &b00001000, &b00111110, &b00001000, &b00010100 ' asteriska
Data &b00001000, &b00001000, &b00111110, &b00001000, &b00001000 ' plus
Data &b00000000, &b00000101, &b00000110, &b00000000, &b00000000 ' comma
Data &b00001000, &b00001000, &b00001000, &b00001000, &b00001000 ' minus
Data &b00000000, &b00000011, &b00000011, &b00000000, &b00000000 ' full_stop
Data &b00000010, &b00000100, &b00001000, &b00010000, &b00100000 ' forward_slash
Data &b00111110, &b01000101, &b01001001, &b01010001, &b00111110 ' zero
Data &b00000000, &b00100001, &b01111111, &b00000001, &b00000000 ' one
Data &b00100001, &b01000011, &b01000101, &b01001001, &b00110001 ' two
Data &b01000010, &b01000001, &b01010001, &b01101001, &b01000110 ' three
Data &b00001100, &b00010100, &b00100100, &b01111111, &b00000100 ' four
Data &b01110010, &b01010001, &b01010001, &b01010001, &b01001110 ' five
Data &b00011110, &b00101001, &b01001001, &b01001001, &b00000110 ' six
Data &b01000000, &b01000111, &b01001000, &b01010000, &b01100000 ' seven
Data &b00110110, &b01001001, &b01001001, &b01001001, &b00110110 ' eight
Data &b00110000, &b01001001, &b01001001, &b01001010, &b00111100 ' nine
Data &b00000000, &b00110110, &b00110110, &b00000000, &b00000000 ' colon
Data &b00000000, &b00110101, &b00110110, &b00000000, &b00000000 ' semicolon
Data &b00001000, &b00010100, &b00100010, &b01000001, &b00000000 ' less_than
Data &b00010100, &b00010100, &b00010100, &b00010100, &b00010100 ' equals
Data &b00000000, &b01000001, &b00100010, &b00010100, &b00001000 ' greater_than
Data &b00100000, &b01000000, &b01000101, &b01001000, &b00110000 ' question_mark
Data &b00100110, &b01001001, &b01001111, &b01000001, &b00111110 ' at
Data &b00111111, &b01000100, &b01000100, &b01000100, &b00111111 ' A
Data &b01111111, &b01001001, &b01001001, &b01001001, &b00110110 ' B
Data &b00111110, &b01000001, &b01000001, &b01000001, &b00100010 ' C
Data &b01111111, &b01000001, &b01000001, &b00100010, &b00011100 ' D
Data &b01111111, &b01001001, &b01001001, &b01001001, &b01000001 ' E
Data &b01111111, &b01001000, &b01001000, &b01001000, &b01000000 ' F
Data &b00111110, &b01000001, &b01001001, &b01001001, &b00101111 ' G
Data &b01111111, &b00001000, &b00001000, &b00001000, &b01111111 ' H
Data &b00000000, &b01000001, &b01111111, &b01000001, &b00000000 ' I
Data &b00000010, &b00000001, &b01000001, &b01111110, &b01000000 ' J
Data &b01111111, &b00001000, &b00010100, &b00100010, &b01000001 ' K
Data &b01111111, &b00000001, &b00000001, &b00000001, &b00000001 ' L
Data &b01111111, &b00100000, &b00011000, &b00100000, &b01111111 ' M
Data &b01111111, &b00010000, &b00001000, &b00000100, &b01111111 ' N
Data &b00111110, &b01000001, &b01000001, &b01000001, &b00111110 ' O
Data &b01111111, &b01001000, &b01001000, &b01001000, &b00110000 ' P
Data &b00111110, &b01000001, &b01000101, &b01000010, &b00111101 ' Q
Data &b01111111, &b01001000, &b01001100, &b01001010, &b00110001 ' R
Data &b00110001, &b01001001, &b01001001, &b01001001, &b01000110 ' S
Data &b01000000, &b01000000, &b01111111, &b01000000, &b01000000 ' T
Data &b01111110, &b00000001, &b00000001, &b00000001, &b01111110 ' U
Data &b01111100, &b00000010, &b00000001, &b00000010, &b01111100 ' V
Data &b01111110, &b00000001, &b00001110, &b00000001, &b01111110 ' W
Data &b01100011, &b00010100, &b00001000, &b00010100, &b01100011 ' X
Data &b01110000, &b00001000, &b00000111, &b00001000, &b01110000 ' Y
Data &b01000011, &b01000101, &b01001001, &b01010001, &b01100001 ' Z
Data &b00000000, &b01111111, &b01000001, &b01000001, &b00000000 ' left_square
Data &b00100000, &b00010000, &b00001000, &b00000100, &b00000010 ' back_slash
Data &b00000000, &b01000001, &b01000001, &b01111111, &b00000000 ' right_square
Data &b00010000, &b00100000, &b01000000, &b00100000, &b00010000 ' circumflex
Data &b10000000, &b10000000, &b10000000, &b10000000, &b10000000 ' underscore
Data &b00000000, &b01000000, &b00100000, &b00010000, &b00000000 ' grave_accent
Data &b00000010, &b00010101, &b00010101, &b00010101, &b00001111 ' a
Data &b01111111, &b00001001, &b00001001, &b00001001, &b00000110 ' b
Data &b00001110, &b00010001, &b00010001, &b00010001, &b00010001 ' c
Data &b00000110, &b00001001, &b00001001, &b00001001, &b01111111 ' d
Data &b00001110, &b00010101, &b00010101, &b00010101, &b00001101 ' e
Data &b00000000, &b00001000, &b00111111, &b01001000, &b00100000 ' f
Data &b00001001, &b00010101, &b00010101, &b00010101, &b00011110 ' g
Data &b01111111, &b00001000, &b00001000, &b00001000, &b00000111 ' h
Data &b00000000, &b00000000, &b00101111, &b00000000, &b00000000 ' i
Data &b00000010, &b00000001, &b00000001, &b01011110, &b00000000 ' j
Data &b00000000, &b01111111, &b00000100, &b00001010, &b00010001 ' k
Data &b00000000, &b01000001, &b01111111, &b00000001, &b00000000 ' l
Data &b00011111, &b00010000, &b00001110, &b00010000, &b00011111 ' m
Data &b00011111, &b00001000, &b00010000, &b00010000, &b00001111 ' n
Data &b00001110, &b00010001, &b00010001, &b00010001, &b00001110 ' o
Data &b00011111, &b00010100, &b00010100, &b00010100, &b00001000 ' p
Data &b00001000, &b00010100, &b00010100, &b00010100, &b00011111 ' q
Data &b00011111, &b00001000, &b00010000, &b00010000, &b00001000 ' r
Data &b00001001, &b00010101, &b00010101, &b00010101, &b00010010 ' s
Data &b00010000, &b00010000, &b01111110, &b00010001, &b00010010 ' t
Data &b00011110, &b00000001, &b00000001, &b00000001, &b00011110 ' u
Data &b00011100, &b00000010, &b00000001, &b00000010, &b00011100 ' v
Data &b00011110, &b00000001, &b00000110, &b00000001, &b00011110 ' w
Data &b00010001, &b00001010, &b00000100, &b00001010, &b00010001 ' x
Data &b00010000, &b00001001, &b00000110, &b00001000, &b00010000 ' y
Data &b00010001, &b00010011, &b00010101, &b00011001, &b00010001 ' z
Data &b00001000, &b00110110, &b01000001, &b01000001, &b00000000 ' leftcurly
Data &b00000000, &b00000000, &b01111111, &b00000000, &b00000000 ' vertline
Data &b00000000, &b01000001, &b01000001, &b00110110, &b00001000 ' rightcurly
Data &b00000100, &b00001000, &b00001000, &b00001000, &b00010000 ' tilde
Data &b01111111, &b01000001, &b01000001, &b01000001, &b01111111 ' del
buildDisplayData:
scrollcount=0
textpos=0
For k=1 To Len(mytext$)
chartext=Asc(Mid$(mytext$,k,1))
chartext=chartext-32
displaydigit0((k-1)*6)=characters(chartext,0)
displaydigit0((k-1)*6+1)=characters(chartext,1)
displaydigit0((k-1)*6+2)=characters(chartext,2)
displaydigit0((k-1)*6+3)=characters(chartext,3)
displaydigit0((k-1)*6+4)=characters(chartext,4)
If chartext=63 Then
displaydigit0((k-1)*6+5)=&b10000000
Else
displaydigit0((k-1)*6+5)=0
EndIf
scrollcount=scrollcount+6
Next k
displaydigit0(scrollcount+0)=0
displaydigit0(scrollcount+1)=0
displaydigit0(scrollcount+2)=0
displaydigit0(scrollcount+3)=0
displaydigit0(scrollcount+4)=0
displaydigit0(scrollcount+5)=0
Return
I think the junk2 spi command was because I had a 74HC595 chip in the loop as well(not video'd)
Video is of version 3.1, whilst code is for v3.2
Regards Dennis
vk4tec
Posted: 01:05am 16 Nov 2012
I have used a futurelec board 8x7 led display .
Gps clock display max chip does the digital signal to display control
I can send code
It is very much down to basic control and timing
Andrew vk4tec
Andrew Rich VK4TEC
www.tech-software.net
Talbit
Posted: 04:16pm 17 Nov 2012
Thanks gents,
Andrew, I'd be very interrested to see your circuit and code.
Email me direct if you prefer or post here.
trevjan@bigpond.com
Talbit
Talbit
Posted: 06:49pm 17 Nov 2012
  Talbit said   Thanks gents,
Post here for us all to see please!! Pretty Please...
vk4tec
Posted: 08:29pm 17 Nov 2012
The Board I used was a Futerlec 8x7 SEG LED display GPS CLOCK
The MAX chip uses SPI.
You need to toggle PIN 15
I used the SPI
First section sets up the board ( please see MAX / Futurelec board )
http://www.futurlec.com.au/8x7_Segment.jsp
Then the digits part sets "12345678"
Rem FUTURELEC 7 segment x 8 LED
Rem Andrew Rich Apr 2012
SetPin 16,2
SetPin 17,8
SetPin 18,8
SetPin 15,8
Pin(15) =0
Pause 10
a = SPI(16,17,18,&H0A,L)
a = SPI(16,17,18,&H02,L)
Pin(15)=1
Pause 10
Pin(15) =0
Pause 10
a = SPI(16,17,18,&H0B,L)
a = SPI(16,17,18,&H07,L)
Pin(15)=1
Pause 10
Pin(15) =0
Pause 10
a = SPI(16,17,18,&H09,L)
a = SPI(16,17,18,&Hff,L)
Pin(15)=1
Pause 10
Pin(15) =0
Pause 10
a = SPI(16,17,18,&H0C,L)
a = SPI(16,17,18,&H01,L)
Pin(15)=1
Pause 10
Pin(15) =0
Pause 10
a = SPI(16,17,18,&H0F,L)
Pin(15)=1
Pause 10
Pause 2000
Pin(15) =0
Pause 10
a = SPI(16,17,18,&H00,L)
Pin(15)=1
Pause 10
Rem digits
Pin(15) =0
Pause 10
Pin(15)=1
Pause 10
Pin(15) =0
Pause 10
Pin(15)=1
Pause 10
Pin(15) =0
Pause 10
a = SPI(16,17,18,&H03,L)
Pin(15)=1
Pause 10
Pin(15) =0
Pause 10
a = SPI(16,17,18,&H04,L)
Pin(15)=1
Pause 10
Pin(15) =0
Pause 10
a = SPI(16,17,18,&H05,L)
Pin(15)=1
Pause 10
Pin(15) =0
Pause 10
a = SPI(16,17,18,&H06,L)
Pin(15)=1
Pause 10
Pin(15) =0
Pause 10
Pin(15)=1
Pause 10
Pause 1000
Pin(15) =0
Pause 10
a = SPI(16,17,18,&H08,L)
Pin(15)=1
Pause 10
Andrew Rich VK4TEC
vk4tec
Posted: 08:33pm 17 Nov 2012
Rem FUTURELEC GPS 7 segment x 8 LED
max = 20 ' maximum nbr of params
Dim arg$(max) ' used to hold the data fields
SetPin 16,2
SetPin 17,8
SetPin 18,8
SetPin 15,8
Rem
Pin(15) =0
Pause 10
Pin(15)=1
Pause 10
Rem
Pin(15) =0
Pause 10
Pin(15)=1
Pause 10
Rem
Pin(15) =0
Pause 10
Pin(15)=1
Pause 10
Rem
Pin(15) =0
Pause 10
Pin(15)=1
Pause 10
Rem TEST MODE
'Pin(15) =0
'Pause 10
'a = SPI(16,17,18,&H0F,L)
'a = SPI(16,17,18,&H01,L)
'Pin(15)=1
'Pause 10
'Pause 2000
'Pin(15) =0
'Pause 10
'a = SPI(16,17,18,&H00,L)
'Pin(15)=1
'Pause 10
Open "COM3:19200" As #1
nmea_sentence
If arg$(0) = "GPRMC" Then
Rem GPRMC values
Print arg$(1)
tme$ = arg$(1)
utchr$ = Mid$(arg$(1),1,2)
utchr = Val(utchr$)
If utchr > 13 Then
lclhr = utchr - 14
EndIf
If utchr < 14 Then
lclhr = utchr + 10
EndIf
utcmn$ = Mid$(arg$(1),3,2)
utcmn = Val(utcmn$)
lclhr$ = Format$(lclhr,"%02g")
lclmn$ = Format$(utcmn,"%02g")
digit1$ = Mid$(arg$(1),6,1)
Pin(15) =0
Pause 10
a = SPI(16,17,18,Val(digit1$),L)
Pin(15)=1
Pause 10
digit2$ = Mid$(arg$(1),5,1)
Pin(15) =0
Pause 10
a = SPI(16,17,18,Val(digit2$),L)
Pin(15)=1
Pause 10
Pin(15) =0
Pause 10
a = SPI(16,17,18,10,L)
Pin(15)=1
Pause 10
digit3$ = Mid$(arg$(1),4,1)
Pin(15) =0
Pause 10
a = SPI(16,17,18,Val(digit3$),L)
Pin(15)=1
Pause 10
digit4$ = Mid$(arg$(1),3,1)
Pin(15) =0
Pause 10
a = SPI(16,17,18,Val(digit4$),L)
Pin(15)=1
Pause 10
Pin(15) =0
Pause 10
Pin(15)=1
Pause 10
digit5$ = Mid$(lclhr$,2,1)
Pin(15) =0
Pause 10
a = SPI(16,17,18,Val(digit5$),L)
Pin(15)=1
Pause 10
digit6$ = Mid$(lclhr$,1,1)
Pin(15) =0
Pause 10
a = SPI(16,17,18,Val(digit6$),L)
Pin(15)=1
Pause 10
EndIf
Loop
Rem -- SUBS --
Sub nmea_sentence
msg$ ="$" ' subroutine start
Do While Input$(1, #1) <> "$" : Loop ' wait for the start
For i = 0 To max
arg$(i) = "" ' clear ready for data
Do ' loops until a specific exit
x$ = Input$(1, #1)
msg$ = msg$ + x$ ' get the character
If x$ = "," Then Exit ' new data field, increment i
If x$ = "*" Then Return ' we have all the data so return
arg$(i) = arg$(i) + x$
'Print arg$(i) ' add to the data
Loop
'Print arg$(i) ' loop back for the next char
Next i ' move to the next data field
' Print "Corrupt data..." ' exceeded max data items
'Print msg$
Loop
End Sub
Andrew Rich VK4TEC
Talbit
Posted: 08:57pm 17 Nov 2012
Thanks Andrew,
Fantastic! I'm getting lazy in my old age.
I can certainly make use of your efforts.
Talbit
Talbit
Talbit
Posted: 09:43pm 17 Nov 2012
Andrew,
That looks like a great board. I've ordered one already. Sensible price too.
Can you tell how long it takes to update the display? I see you've been doing a lot of GPS work.
Talbit.
Talbit
