Local Time 06:44 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Maximite GPS 5hz logger gps18
vk4tec
Posted: 01:06pm 02 Nov 2012
Hello
I have successfully used the GPS-mod with Duinomite as an sd card GPS logger at 1 hz
Got a maximite now
Garmin GPS 18 5 hz
Should be ok ?
TTL inverted nmea data
19k2
5 volts from maximite
Andrew
Andrew Rich VK4TEC
www.tech-software.net
vk4tec
Posted: 01:47pm 02 Nov 2012
what are the pinouts on a maximite non colour
CON9 - IDC connector
looking for GND 5V Serial RX TX
GPS
- Andrew -
Andrew Rich VK4TEC
centrex
Posted: 03:45pm 02 Nov 2012
Andrew
You could look up the details here.
http://geoffg.net/maximite.html
centrex
Cliff
vk4tec
Posted: 08:54pm 02 Nov 2012
Found it
GPS18 15 Hz is TTL PC compatible not UART compatible.
Andrew Rich VK4TEC
Posted: 09:51pm 02 Nov 2012
The maximite serial ports are 5V tolerant so that is not a problem.
You may need to put a simple inverter in to get the polarity correct.
vk4tec
Posted: 02:46pm 15 Nov 2012
I did some more work on this one
GARMIN GPS18 5Hz is TTL PC compatible
I used a MAX232 to turn the logic upside down.
I have tried a 1Hz GPS and a 5 Hz GPS logging to SD CARD
I found the 5 Hz was a bit much for the PIC to keep up with for reading from serial and then writing to SD CARD.
The 1 Hz works ok, but it did bomb out not being able to write to the SD card once
I will experiement more
open "COM2:19200,1024" as #1 ( 1kb buffer )
I know the 5 Hz is loosing data because it normally has
Time : .0
Time : .2
Time : .4
Time : .6
Time : .8
The display on the VGA shows some missing lines.
I will play some more and report back.
I am using COM2 under DM MMBasic 4.0B
- Andrew -
Andrew Rich VK4TEC
Posted: 08:09pm 15 Nov 2012
19200 baud is about 1920 characters per second.
How long are the individual messages?
Maybe 19200 baud is too low.
vk4tec
Posted: 12:57am 16 Nov 2012
I have a question about file handles
I was open file for append and close sd card file each time a new nmea line came in.
But it is also possible to open the file and leave it open and simply append to the file without closeing it each time a new gps line comes in
Is there any chance of loss of data if you don't keep closing the file off ?
What does open and close file actually do ?
It there any performance to be gained from opening the file once instead of open and close all the time ?
Andrew vk4tec
Andrew Rich VK4TEC
Posted: 02:55am 16 Nov 2012
Opening and closing files is a performance hit. Even on a 2Ghz PC it can be noticeable.
You could buffer a certain amount of data and then write that in one go.
If you have a 1k buffer for the com port, you might also buffer about 1k of data before appending it to the file.
Posted: 02:19pm 17 Nov 2012
> Is possible to open the file and leave it open and simply append to the file without closeing it each time a new gps line comes in?
Yes, that would work fine.
If you do not close the file and there is a power failure you could easily end up with a corrupted file or worse a corrupted SD card.
Opening a file involves reading the file structure into a memory buffer which is updated as the file is written to. Closing closing the file will write the file structure back to the SD card.
> Yes, it is faster but the time involved in opening/appending/closing is not great. Especially as you are only logging data once a second.
The bigger issue would be the wear on the SD card flash memory. Opening and closing a file causes a rewrite of the FAT and if you do that once a second you could wear out the card in a few weeks.
vk4tec
Posted: 08:18pm 17 Nov 2012
I am using some code that does this
1. Get a character from the serial port
2. See if it is a "*" is so, close of the string we have reached the end of the line
3. See if it is a "," is so, we have grabbed the next arg$
Something like this
$GPRMC,000009.000,A,2720.2450,S,15302.5998,E,0.00,340.05,080 412,,,A*7B
Each character and each comma is interpretted.
Very labour intensive
If the a input$ syntax that just lets be "grab a line"
All I am really intested is the whole lines that BEGIN with GPRMC GPGGA
- Andrew -
Andrew Rich VK4TEC
vk4tec
Posted: 09:08pm 17 Nov 2012
I am trying LINE INPUT
- Andrew -
Andrew Rich VK4TEC
