Forum Index : Microcontroller and PC projects : MM basic 4.0 for duinomite mega
plasma
Posted: 12:51am 27 Oct 2012
Hi ppls,
Is where a MMBasic 4.0 for the duinomite with support for com3/com4 with 115200 baud ?
I have installed 3,2 which works not up to 115200 .
plasma
Posted: 08:37am 29 Oct 2012
109 viewer without a comment ?
Whats the point ?
Posted: 09:37am 29 Oct 2012
  plasma said   Hi ppls,
I believe NOT... As Geoff has just ported the standard MM4 (mono) to the DM, therefore as the Standard MM doesnt support COM 3 and 4 or 115k baud, the port to the DM wont either.
Posted: 09:42am 29 Oct 2012
I have no way of testing the Duinomite serial ports but the Change log has this:
Change log for MMBasic Ver 3.2A
Baud rates for the hardware serial ports of the DuinoMite can now be set to any speed (ie,
they do not have to be multiples of 300).
Fixed a bug that caused MMBasic to freeze when the baud rate was specified for COM3:
and COM4: (DuinoMite only).
So it is worth trying V3.2A or V4.0 to see if it has fixed your problem.
plasma
Posted: 10:35am 29 Oct 2012
Ok thx a lot !
I will test it out and send my comments about later.
Thx again
Posted: 03:51am 30 Oct 2012
I was one of the viewers but could not understand the question but in any case thought Geoff's manual would probably already say. Plus he has his own forum I believe.
