Forum Index : Microcontroller and PC projects : MM Edit - Connect to DM Mega via USB
panky
Posted: 08:21pm 03 Oct 2012
Hi Folks,
I am using TassieJim's MM Edit program with my DM Mega and it's great. Is anyone else using it with a USB connection to their PC? If so, is there anyway to to have the interaction with the DM the same way as with TerraTerm? I have a program that sends all the output to the display using print @ (which works fine in TerraTerm) but with the MM Basic interactive window, I get all the Escape codes printed rather than processed as per a VT100 emulation on TerraTerm?
MM Edit v 2.0.3 and MM Basic V4.0
Posted: 03:32pm 04 Oct 2012
  panky said   Hi Folks,
Not at the moment but is something I have been actively thinking about.
I know that I have no hope of emulating TerraTerm but I want to have the option on basic VT commands recognised.
I am also playing with a method of detecting when you unplug the MM with the comms window open to stop the rather dramatic crash which occurs at the moment.
I have made some progress but Microchip seem to be the only USB-serial device that I cannot reliably get 'Windows messages' from!
I am VERY busy with a family matter for the foreseeable future so I will not try to gave a timeline.
panky
Posted: 07:38pm 04 Oct 2012
Jim, Thanks again for a great program and appreciate your response, Cheers, Doug.
