Forum Index : Microcontroller and PC projects : DM I2C LSM303DLM
jlder
Posted: 02:57am 30 Sep 2012
I am trying to connect to an LSM303DLM which is on a 9DOF Drotek board using I2C with a DM eMega.
Up to known I have had zero luck.
I connected the external board to UEXT 1 for Vdd, 2 for GND, 5 for clock and 6 for data.
I used the following code to:
- initialize I2C
- set the chipo to 30 Hz
- set the gain for 1.3 Gauss
- set the continuous mode
- and read the 6 byte to get the 3 axis.
I test MM.I2C after each I2C instruction and get a nack every time.
What is strange is that I also get nack when ecternal board is not powered.
Any advise on what I am doing wrong?
Thanks,
JLD
Here is the code (line numbers are supposed to go every 10).
MAGXH=0
MAGXL=0
MAGYH=0
MAGYL=0
MAGZH=0
MAGZL=0
I2CEN 100,100 'enable I2C
I2CSEND &H1E, 1, 2, &H00, &H14 'ODR to 30 Hz
? "0=ok 1=nack 2=timeout"; MM.I2C
I2CSEND &H1E, 1, 2, &H01, &H20 'Gain for 1.3 Gauss
I2CSEND &H1E, 1, 2, &H02, &H00 'Continuous mode
I2CRCV &H1E, 1, 1, MAGXH, 1, &H03 'read X high
I2CRCV &H1E, 1, 1, MAGXL, 1, &H04 'read X low
I2CRCV &H1E, 1, 1, MAGYH, 1, &H05 'read Y high
I2CRCV &H1E, 1, 1, MAGYL, 1, &H06 'read Y low
I2CRCV &H1E, 1, 1, MAGZH, 1, &H07 'read Z high
I2CRCV &H1E, 1, 1, MAGZL, 1, &H08 'read Z low
PRINT "X ="; HEX$(MAGXH*256+MAGXL); TAB(10);
PRINT "Y ="; HEX$(MAGYH*256+MAGYL); TAB(20);
PRINT "Z ="; HEX$(MAGZH*256+MAGZL)
IF INKEY$ <> "" THEN 320 'end if key is pressed
PAUSE 300 'wait a little
GOTO 140 'read and print again
I2CDIS
BobD
Posted: 09:29am 30 Sep 2012
You should have a read of this http://www.pololu.com/catalog/product/1273 especially the part about addresses and Protocol Hints.
