Local Time 06:03 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SPRITE on MM
ajkw
Posted: 01:23am 21 Aug 2012
In regards sprites on a MM.
How do you draw a white pixel on a black ground? I have tried every number from 0 to 7 but they only seem able to draw a black pixel on a white background. I can get transparent pixels (with a space) on a white back ground all ok.
I am on version 4.0 of course.
Cheers,
Anthony.
Edited by ajkw 2012-08-22
Posted: 02:04am 21 Aug 2012
Ah, sorry about that Anthony. You have discovered a bug in the monochrome version related to sprite handling. It was not picked up in testing because most sprite testing concentrated on the colour version.
There is no workaround so the fix will have to wait for the next update.
