Forum Index : Microcontroller and PC projects : duinomite mmbasic old nokia phone AT com
LG046
Posted: 03:05am 11 Aug 2012
hi
i have a old nokia phone that can work with AT commands
using hyperterminal i can get it to call a number like this
ATD=XXXXXXX ( xxx stand for the phone number )
now i have MMbasic on my duinomite mega and want to do the same
when i do OPEN com4:9600 as console
and type at the prompt ATD=xxxxxx and hit enter it works
but when i do the following code its not working
10 cls
20 open "com4:9600" As #1
30 print #1, "ATD=xxxxx"
40 close #1
the phone is not calling the number..........
Edited by LG046 2012-08-12
LG046
Posted: 11:01am 11 Aug 2012
nobody?
31 views...
maybe get the mod-gsm then.....
would be nice to use the old cellphone is a Nokia 6310i with serial com cable.
otherwise its going to be recycled and ofcourse for a mod-gsm i need to spent some money -(
ajkw
Posted: 12:55pm 11 Aug 2012
Does the Nokia connection cable require drivers that the MM doesn't have?
jebz
Posted: 01:04pm 11 Aug 2012
Maybe it needs some handshaking or a pause between the characters.
Posted: 01:40pm 11 Aug 2012
  LG046 said  when i do OPEN com4:9600 as console
That just sets the variable ATD to xxxxxx but as the characters that you typed are echoed on the serial port (opened as console) your phone still gets the string terminated by a single carriage return.
The PRINT command on line 30 adds a carriage return/line feed at the end. Is this what you want?
Use the semicolon to suppress the CR/LF and chr$(13) to generate a single carriage return. Ie:
30 print #1, "ATD=xxxxx" chr$(13) ;
LG046
Posted: 09:17pm 11 Aug 2012
hi thx
i am now trying to send a text message out.
i made some changes.. funny thing is i run the code and get a text message on my phone not only displaying the "example text" but also parts of the code hahaha
and when i run it again , just run edited nothing its no longer working
after a while i can run it again and then it sends out a sms txt again
here is my code
10 Cls
15 Open "COM4:9600" As #1
16 Print #1, "AT" Chr$(13) : Pause 1000
17 Print #1, "AT+CVHU=0" Chr$(13) : Print #1, "at+cvhu" Chr$(13) : Pause 1000
20 Print #1, "AT+CMGF=1" Chr$(13) ; : Pause 1000
22 Print #1, "AT+CMGS=" : Pause 250
23 Print #1, Chr$(34) : Pause 250
24 Print #1, "XXXXXXXXX" : Pause 250
25 Print #1, Chr$(34) : Pause 250
26 Print #1, Chr$(13) : Pause 250
27 Print #1, "example text" : Pause 250
28 Print #1, Chr$(26) : Pause 250
23 Pause 1000
26 Print #1, "ath" Chr$(13) ;
27 Pause 1000
30 Close #1
EDIT
made some changes
10 Cls
' 16 Print #1, "AT" Chr$(13) ; : Pause 1000
' 17 Print #1, "AT+CVHU=0" Chr$(13) : Print #1, "at+cvhu" Chr$(13) ; : Pause 250
20 Print #1, "AT+CMGF=1" ; : Pause 250 ' set sms to text mode
21 Print #1, Chr$(13) ; : Pause 250
22 Print #1, "AT+CMGS=" ; : Pause 250 'send sms
23 Print #1, Chr$(34) ; : Pause 250
24 Print #1, "xxxxxxxxxxxxxxxx" ; : Pause 250 'set phone number to send to
25 Print #1, Chr$(34) ; : Pause 250
26 Print #1, Chr$(13) ; : Pause 250
27 Print #1, "example text" ; : Pause 250 'text to send
28 Print #1, Chr$(26) ; : Pause 250
' 23 Pause 1000
26 Print #1, "ath" Chr$(13) ; : Pause 250 'close any connections if not on hook
' 27 Pause 1000
30 Close #1
this works i also only get the example text now in my text message
but when i run this command and its finisched i can not run it again.. i have to wait like minutes to be able to send a text message again.....Edited by LG046 2012-08-13
