Local Time 05:35 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : New MAXIMITE
vk4tec
Posted: 04:00am 29 May 2012
Hello
From getting it in the mail to firmware flash and first program in about an hour.
Happy vegemite
Maximite ex Altronics
- Andrew -
Andrew Rich VK4TEC
www.tech-software.net
Bugs2
Posted: 07:42am 29 May 2012
well, your doing better than me! I'm still having problems trying to reprogramme a DuinoMite-Mini with the latest version of MMBasic. Not sure whether its me (most likely)or documentation errors.
Please could you do a step-by-step guide for the rest of us?
vk4tec
Posted: 10:27am 29 May 2012
How to re-flash a DuinoMite Mini
Remove all power from the board
Ensure the jumper EXT / USB is across "USB"
Now connect the USB cable to the board
You should have red LED and yellow LED ON
Hold down the reset button ( black ) AND then press the user button ( cream )
Keep holding down the USR ( cream button ) and release the black reset button.
As soon as you release the reset button, yellow and green LED flash back and forth
Run program "HIDprogrammer.exe" USB bootloader V2.90a for Olimex Boards
Program should say "Device Attached" "Connecting...." "Device Ready"
Files "import Firmware Image"
Select .hex file containing image.
Says "Opened: DuinoMite_MMBasic_V3.2A.hex"
Now "Program" , "Erase/Program/Verify" device
LED will stop flash, then flash some more
Bar will progress
Starting Erase/Program/Verify Sequence.
Do not unplug device or disconnect power until the operation is fully complete.
Erasing Device... (no status update until complete, may take several seconds)
Erase Complete (3.172s)
Writing Device Program Memory...
Writing Complete (6.109s)
Verifying Device's Program Memory...
Verifying Complete (141.469s)
Erase/Program/Verify Completed Successfully.
You may now unplug or reset the device.
Now reset ( black button ) and exit program
LED stop flashing, just yellow and red LED
- Andrew -
Andrew Rich VK4TEC
donmck
Posted: 12:03pm 29 May 2012
Thanks Andrew, have added your explanation to the bottom of:
http://www.duinomite.com/duinomite-firmware-update-guide/
Hopefully this will assist users still having problems with this procedure.
Cheers Don...
https://www.dontronics.com
djuqa
Posted: 02:53pm 29 May 2012
Ditto
details posted on duinomite.com.au
VK4MU MicroController Units
donmck
Posted: 02:57pm 29 May 2012
  djuqa said
Ditto
David, none of your sig links are correct.
Cheers Don...
djuqa
Posted: 03:01pm 29 May 2012
they are now thanks
Bugs2
Posted: 10:29pm 29 May 2012
Many thanks vk4tec for that detailed explanation. I can see where some original bits of documentation may have lead me astray, but will now have another go and let you know how it goes.
Bugs2
Posted: 08:14am 03 Jun 2012
Just tried reprogramming by following vK4tec's very clear instructions and every stage worked just fine! Thanks again.
donmck
Posted: 10:58am 03 Jun 2012
  Bugs2 said   Just tried reprogramming by following vK4tec's very clear instructions and every stage worked just fine! Thanks again.
Great news Mike, glad you eventually got there, and also verified that Andrew's instructions must be spot on.
Cheers Don...
