Local Time 05:35 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic V3.2 for CGMMSTICK?
Bugs2
Posted: 08:31am 23 May 2012
Please can anyone tell me if the CGMMSTICK, and it's associated MMIDE, will be updated from MMBasic 2.7 to 3.2?
CircuitGizmos
Posted: 09:38am 23 May 2012
The CGMMSTICK1 can be loaded with the newest MMBasic (the normal Maximite compatible release) easily. You just need to follow the firmware update routines.
Most of the MMIDE is fine with MMBasic 3.2. Only the Edit capability isn't supported.
Bugs2
Posted: 09:47pm 23 May 2012
Apart from having to invest more development time in the already excellent MMIDE, is there any other reason why the CGMMSTICK is not shipped with a more recent version of MMBASIC?
CircuitGizmos
Posted: 03:08am 24 May 2012
There was a large production run of CGMMSTICK1 boards produced. They were all programmed when produced and loaded with the firmware that was current at the time. Next run will use newer firmware.
There is little connection between MMIDE development and the firmware, other than MMIDE works with MMbasic 3.0+.
Bugs2
Posted: 03:26am 24 May 2012
Thanks for the CGMMSTICK update. Just wish that this product generated as much interest in the educational sector as the over-hyped Raspberry Pi seems to be doing. The Stick is mechanically more suited to breadboard experimentation and Basic is the perfect 'Beginners' language.
CircuitGizmos
Posted: 08:53am 24 May 2012
Thanks! Yes, the CGMMSTICK1 doesn't have the flash of the Pi, but it does what embedded systems are supposed to do. The Pi seems to be a PC pushed to be an embedded device.
