Local Time 22:57 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Maximum File Upload size
Ray B
Posted: 08:12am 13 May 2012
I'm trying to upload a pdf or even zip file which is approx 1.2 MB in size but it fails. What is the true maximum file size allowed ???
RayB from Perth WA
Posted: 08:18am 13 May 2012
Well it should be 20 meg, according to the forum configuration. What does it say when it fails? Is there a error message, or does it just time out?
Ray B
Posted: 12:06pm 13 May 2012
Glenn I recall seeing this problem before. I've just completed some trials and PDF files as they get over 450KB or so seem to not be able to be uploaded.
The original doc I has was a 3 page Word document with some imbedded images which send the file size over the top being approx 1.2MB. To overcome this problem I've now uploaded the document as 4 separate PDF pages & that worked OK - refer to my other post of today.
Glenn if you want the original failed file for test purposes let me know through PM and I can email it to you if you desire.
Regards all
RayB from Perth WA
Posted: 12:16pm 13 May 2012
Hi Ray
Sent you a PM.
