Local Time 05:23 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Hyperterminal problem
VK4SMC
Posted: 04:36am 13 May 2012
Hi all,
Just FYI I have been using Hyperterminal on my Windows XP computer successfully with MMbasis V3.2A until when I tried today.
Connects to Maximite OK but when I try Auto to paste in some code, it double spaces between lines and then won't go into Editor screen.
Last night as I shutdown, windows had some updates and I do suspect this may be part/all of the problem.
I just down loaded Tera Term and all seems fine.
I am not concerned about the problem at all.
It just may save someone from going through a hundred different checks as I just did.
Steve
VK4SMC
Steve VK4SMC
