Local Time 05:23 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Using ThePCF8563 RTC with MMBasic
davefaw
Posted: 09:43pm 11 May 2012
Hi All, I have built my own pcb with a PIC32 and an RTC using the PCF8563 RTC Chip. I am able to read the RTC ok through the I2C bus but seem unable to write to it. Has anybody out there got any sample code that they have used to access the PCF8563 on the I2C bus? I have MMBasic 3.2A loaded.
Dave
jman
Posted: 09:59pm 11 May 2012
Hi Dave
Here is all you need
http://www.thebackshed.com/forum/forum_posts.asp?TID=3790&KW =jman
JohnEdited by jman 2012-05-13
davefaw
Posted: 06:37am 12 May 2012
Thanks for that john, but this is for the DS1307 RTC, without sifting through reams of Data sheets, I'm not sure if they are the same..... Dave
jman
Posted: 06:42am 12 May 2012
Hi
Scroll to the second page of that thread I used a PCF8563
Code is posted in the same thread
centrex
Posted: 07:11am 12 May 2012
First set the time and date on the maximite.
Then run this....
600 ' Get time from time$ and date$
610 tempdec = VAL(LEFT$(TIME$, 2))
615 GOSUB 1100
617 hours = hex
620 tempdec = VAL(MID$(TIME$, 4, 2))
625 GOSUB 1100
627 minutes = hex
630 tempdec = VAL(RIGHT$(TIME$, 2))
635 GOSUB 1100
637 seconds = hex
640 tempdec = VAL(LEFT$(DATE$, 2))
645 GOSUB 1100
647 day = hex
650 tempdec = VAL(MID$(DATE$, 4, 2))
655 GOSUB 1100
657 month = hex
660 tempdec = (VAL(RIGHT$(DATE$, 4)) - 2000)
665 GOSUB 1100
667 year = hex
670 ' rtcctrl = &h10
680 rtcwday= &h1
690 ' Write Time to RTC
700 i2caddr = &h51 ' PCF8563 I2C address
710 I2CEN 100,100 ' Enable I2C
725 I2CSEND i2caddr, 0, 10, 0, 0, 0, seconds, minutes, hours, day, rtcwday, month, year
730 I2CDIS
770 ? "0=ok 1=nack 2=timeout ";MM.I2C
780 END
1100 ' Convert to Hex
1110 hex = FIX(tempdec / 10) * 16
1120 hex = hex OR ((tempdec / 10) - (FIX(tempdec / 10))) * 10
1140 RETURN
This will set the 8563 to the Maximite time/date.
This is all part of the forum that Jman pointed to.
Have fun centrex
Cliff
Posted: 10:47am 12 May 2012
Would be wiser for 1120 to be
1120 hex = hex OR (tempdec - FIX(tempdec / 10) * 10)
It's because it's unwise to assume that tempdec / 10 * 10 (which is what the original ends up using) results in the number desired!
Saves a division, too, so will be faster and smaller.
OTOH it's a bit odd to be converting a string to decimal and then hex when it could be done directly to hex...
JohnEdited by JohnS 2012-05-13
davefaw
Posted: 04:42pm 12 May 2012
Thanks John, Brilliant service, will try it out tomorrow when I have a bit more time. Dave
davefaw
Posted: 04:43pm 12 May 2012
Thanks to Centrex too.........
BobD
Posted: 06:50pm 12 May 2012
I see the code posted by Centrex in a lot of places. It's like a signature. Someone wrote it way back for RTCs in C and then someone converted it to BASIC. I guess it works for all BASICS.
The Maximite Basic can do it easier because it has integer divide (\) and remainder divide (MOD). As an example, the code above at 650 to 657 can be simplified down to:
' get month number
x = VAL(MID$(DATE$, 4, 2))
month = x\10*16 + x mod 10
similarly when reading the RTC and extracting the Packed BCD (a number in each Nibble or 4 bits of a byte) and converting it to an integer and then to a string, you can do:
' get seconds - range 00 - 59, 7 bits, mask 0x7F
Seconds$=str$((RTCdata(0) and &H70)\16*10 + (RTCdata(0) and &H0F))
Integer divide again simplifies the conversion. The above was for reading a DS3231 RTC. The data for seconds may end up in a different byte of the array RTCdata() when you read another RTC. The MASK is used both to separate the Nibbles and to exclude bits in the RTC register that are unused or used for another function in the particular register.
Posted: 08:04pm 12 May 2012
a faster way of converting a Packed BCD to a string:
(This is actually the reason why RTC chips return values in BCD, when displaying on hardware you don't need to calculate much just put it on an output port, like to a 2 digit 7-segment display via bcd to 7-segment decoders.)
' RTCdata(0) contains 23 (decimal) 17 (hex) 0001 0111 (BCD nibbles) -> 17 seconds
Seconds$ = hex$(RTCdata(0))
' Seconds$ will be "17"
This does not need any extra math.
i have modified the hex$ function to accept a minimumlength parameter. That makes it easy to have a leading zero. I use it like this:
Seconds$ = hex$(RTCdata(0), 2)
' if seconds is lower than 10 the result will have one leading zero
There are many ways to get the same end result. I often use different ways and profile them for speed. I don't have a Maximite yet maybe someone can test which one is the fastest.
From decimal to BCD is also pretty easy:
' when date$ has 17 as the seconds part
hex = val("&H" + LEFT$(DATE$, 2))
' hex will be 23 (decimal) or 17 (hex) and in nibbles 0001 0111
Edited by TZAdvantage 2012-05-14
davefaw
Posted: 07:05pm 13 May 2012
Thanks to all of your help, I have managed to get it working, Phew!! So the code I am using is fine which is derived from the code suggested, however, I have come across a hardware problem thet I don't quite understand, if I connect the two pull up resistors for the I2C bus to the RTC chip's VDD then it works great, if I connect them to +3.3v, before the diode, then it doesn't work. The PCF8563 data sheet says that they should be connected to +3.3V for obvious reasons, it could drain the RTC battery if connected to the chip VDD. Unfortunately, I don't have a storage scope to look at the signals, only a real time one. I also notice that the Olimex MOD-RTC board has the pull ups connected to the Chip VDD, maybe they had the same problem that I have had?........... any comments?
Once again, thanks for all your help......Dave
centrex
Posted: 09:02am 14 May 2012
It would appear from the data sheet that the 8563 draws about 550na when the device is not being accessed so it is probably not a problem.
When you do access the device power would come from the calling computer.
regards
cliff
Cliff
BobD
Posted: 11:01am 14 May 2012
Regarding the pullup resistors. If you are running at 400KHz then try running it at 100KHz instead. What size are the pullup resistors? There is a discussion here about sizing pullups and setting the speed of the bus. It's open to interpretation but the way I read it is size resistors on the low side and same for the speed, if you run into problems.
davefaw
Posted: 11:23am 14 May 2012
Thanks for the link about pull up resistors. I am running at 100kHz and using 10k resistors as recommended in the MMBasic manual, and it is all working great now, but the main question was about where to connect the top end of the pull ups. If I connect to VCC (3.3V) then I can't read the RTC, if I connect to chip VCC the it works fine, but it begs the question, will that drain the RTC battery prematurely? The OLIMEX Duinomite rtc ext board has them connected to the chip (therefore the RTC battery) but in the RTC data sheet it clearly says to connect them to VCC before the diode (which doesn't work for me) Whether it does drain or not depends on the MM pins 12 & 13 and whether the PIC minds having these held up when it has no power connected........ Dave
BobD
Posted: 02:35pm 14 May 2012
Dave
if you want battery operation (who doesn't?) you have to have those resistors away from the chip. I would try 4.7K resistors and even go as low as 2.2K to try and get it working. I have a DS3231 RTC permanently connected with 4.7K resistors. Even with 2.2K resistors they only carry 1.5mA and the PIC can handle up to 25mA on a pin.
davefaw
Posted: 02:49pm 14 May 2012
Thanks for that Bob, I will try some lower value resistors and see if it works. I guessed that it should work with the pull ups on the other side, but don't understand why it doesn't. Will have a play around and let you know. Won't be for a couple of days as I have to do some work sometime!! Dave
davefaw
Posted: 06:22pm 15 May 2012
Great working fine now with the pull-ups on the correct side of the diode. Found that the 100n decoupler at that point was cracked........... replaced it and it all works fine with the 10k pull ups. Thanks everybody for your help. Dave
