Local Time 05:23 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Read PWM duration
cwilt
Posted: 03:39pm 29 Apr 2012
I have a need to read the duration of a PWM pulse. I tried using Setpin pin, 4 for period measurement but no luck. My next idea is to use 2 interupts. One for rising edge, the other for falling, and record the time between.
Any better ideas?
vk4tec
Posted: 11:32am 30 Apr 2012
I know how to do it in Assembly Language
You wait for a rise ( or fall ) and then start a counter.
You wait for a rise ( or fall ) and then stop a counter.
Based on clock speed and instruction cycles, I then know.
And XTAL freq .
- Andrew -
Andrew Rich VK4TEC
www.tech-software.net
cwilt
Posted: 09:10pm 30 Apr 2012
Andrew,
I assumed that is what the duration setting is for setpin, but it always seems to return 0. I am using 2 xbee's to do IO pass through. Analog in on the remote produces a PWM output on the local xbee. Duration varies with voltage on the remote pin.
I have not found any example code using the duration setting. Perhaps I am not doing it in the proper order.Edited by cwilt 2012-05-02
Posted: 10:01pm 30 Apr 2012
  cwilt said   I have a need to read the duration of a PWM pulse. I tried using Setpin pin, 4 for period measurement but no luck. My next idea is to use 2 interupts. One for rising edge, the other for falling, and record the time between.
Any better ideas?
Gday Cwilt,
How small is the smallest expected pulse likely to be? That might help in assisting your answer..
Also is the pulse likely to repeat often etc? (I assume it would)
