Local Time 05:23 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MID$ - two uses
BobDevries
Posted: 12:41am 26 Apr 2012
... but one is missing in MMBASIC. :(
Our MMBASIC has one version of MID$, and that is to grab a sub-string from an existing string variable. However, mid$ should also be able to be used to put a sub-string INTO an existing string variable, like this:
MID$(A$,5,3) = "BOB"
I can't remember offhand if the new substring inserts, or replaces existing characters. I'll need to RTFM :P
And yes, I know code could be written in BASIC to get around this lack....
Bob Devries
Dalby, QLD, Australia
BobDevries
Posted: 12:49am 26 Apr 2012
Hi all,
According to the GWBASIC User's guide, the MID$ statement prototype is:
QUOTE:
MID$(stringexp1,n[,m]) = stringexp2
Both n and m are integer expressions
string exp1 and stringexp2 are string expressions
The characters in stringexp1, beginning at position n, are replaced by the characters in stringexp2.
The optional m refers to the number of characters from stringexp2 that are used in the replacement. If m is omitted, all of stringexp2 is used.
Whether m is omitted or included, the replacement of characters never goes beyond the original length of stringexp1.
ENDQUOTE:
Bob Devries
Posted: 08:02am 26 Apr 2012
It's not intuitive :(
You'd expect stringexp1 to grow or shrink automatically. You'd expect all of stringexp2 to be used. And so on.
Posted: 08:24pm 12 May 2012
It is one of those nasty BASIC statements.
Pretty powerful though. If compatibility is needed it should be implemented.
I am not sure if MID$ can be on the left side of a "=" in the current parser.
I can give it a try...
