Forum Index : Microcontroller and PC projects : Programming microcontrollers in Pascal
Olimex
Posted: 05:35am 25 Apr 2012
Yet another great product from Australia
donmck
Posted: 06:21am 25 Apr 2012
  Olimex said   Yet another great product from Australia
We sell a lite edition with the purchase of selected Olimex boards for $1 extra:
http://www.dontronics-shop.com/astrobe-arm-software-developm ent-system.html
Cheers Don...
https://www.dontronics.com
Posted: 07:47am 25 Apr 2012
If it's going to catch on it has a bit of a cliff to climb!
Olimex
Posted: 08:12am 25 Apr 2012
What is remarkable is that the completely IDE installation is 2MB vs 100MB+ installation for the Arduino/Maple/Pinguino. I like this very much!
I saw the examples and the code generation is also impressive.
The Blnk LED example compiles in just 164 bytes of memory!
(just compare this again with Arduino/Pinguino/Maple code generation size )
djuqa
Posted: 08:14am 25 Apr 2012
I want Oberon/Pascal for Olinuxuino
VK4MU MicroController Units
Posted: 04:30pm 25 Apr 2012
  Olimex said   I saw the examples and the code generation is also impressive.
Imagine almost any p-code type system. The compiled sample will be similarly tiny.
Or any true compiled system that uses shared libraries. C's main() compiles to a small size.
But in each case you're ignoring the other stuff that's needed at runtime.
There again, if you're happy using that language (Oberon/whatever), fine.
It doesn't appear to be open source, which some want - especially when the company behind it may or may not exist in a few years or may have moved to other products.
cfbsoftware
Posted: 03:27am 20 Jun 2012
[quote]Imagine almost any p-code type system. The compiled sample will be similarly tiny.[/quote]
There is just no comparison with p-code systems as they are typically only 10% as efficient as native code compiled systems. The Oberon compiler used in Astrobe generates native 32-bit ARM code for the ARM7 targets or native Thumb2 code for Cortex-M3 targets.
If you want to learn about the architecture of the Oberon compiler and get some understanding of how it compiles so fast and still generates very compact code read Niklaus Wirth's document "An Oberon Compiler for the ARM Processor". He goes into great detail explaining the code that is generated for each language construct:
http://www.inf.ethz.ch/personal/wirth/Articles/Oberon.html
We have been working with Oberon systems since the early 1990's. Our original Astrobe work involved porting Wirth's ARM compiler to Windows for the ARM7 version back in 2008. More recently we have completed rewriting the code generator for the totally different Thumb-2 instruction set for the Cortex-M3 targets. As well as producing more compact code we are now seeing execution speeds about 3x faster.
Cheers,
Chris
Chris Burrows
http://www.astrobe.com
vasi
Posted: 07:23pm 22 Jun 2012
Well, if you like Pascal, specially Turbo Passcal, here are two options for Microchip microcontrollers. One is commercial and I think anyone knows about it - mikroPascal, and another is about Pic Micro Pascal (PMP), free of charge and no limits imposed to the generated code. PMP is for PIC12-PIC18 only, and mikroe support also the other Microchip families, Atmel AVRs, 8051, ARM.
For 8051 microcontrollers, there is a very good Turbo Pascal like compiler, turbo51 (command line only, but you can use a third party editor or IDE).Edited by vasi 2012-06-24
Elvish name: Mablung Miriel
Beyound Arduino Lang
Posted: 09:25pm 22 Jun 2012
For me, C beats all these hands down. YMMV.
cfbsoftware
Posted: 01:02pm 29 Jun 2012
  vasi said  For 8051 microcontrollers, there is a very good Turbo Pascal like compiler, turbo51 (command line only, but you can use a third party editor or IDE).
There has also been an ISO Modula-2 (son of Pascal, father of Oberon) compiler available for some time for the 8051: mod51
Chris Burrows
Edited by cfbsoftware 2012-06-30
