Local Time 05:11 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : GPS position averaging
vk4tec
Posted: 03:12am 25 Apr 2012
Hello
I would like to average my GPS location.
The numbers are like -27 and 153
Am I likely to strike a limit ?
Should I stop it averaging at a particular point ?
The averaging process as I know it is to add up samples and divide by the numeber of samples.
- Andrew -
Andrew Rich VK4TEC
www.tech-software.net
Posted: 07:25am 25 Apr 2012
I don't think you've given remotely enough info.
But... if you get successive numbers (in any data gathering/measuring) that are so wildly different then averaging would normally be a really bad idea. You'd want a way to reject those that are clearly garbage and then do (whatever) with what's left.
vk4tec
Posted: 07:42am 25 Apr 2012
1 Hz GPS
LAT is 27 deg
1 hour = 3600 samples
3600 X 27 = 97200
The PIC must be able to count up to 97200 to average in one hour
27 * 3600 = 97200 ( avg ) / 2600 = 27
To do 24 hours averaging.
27 * 3600 * 24 = 2,332,800 / 3600 * 24 = 27 deg
The worst number encountered in GPS is 180 degrees
180 deg * 3600 * 24 = 15,552,000 / 86400 = 180
So to average 24 hours of GPS data, the PIC has to be able to add up to
15,552,000 ( worst case )
Andrew Rich VK4TEC
Posted: 04:22pm 25 Apr 2012
You want an integer with that range (to 15,552,000)? Yes, they are - comfortably.
