Local Time 05:23 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : IR Remote
jman
Posted: 08:07am 23 Apr 2012
Hi
I was wondering if it would be possible to decode the NEC IR remote protocol with the Maximite. There is lots of info on the protocol to found here NEC Protocol
The code below works pretty well with PicBasic Pro on a 16f629a @ 4Mhz
How would the Pin have to setup on the Maximite ?
Counting input or Peroid input maybe
Any help or thoughts would be greatly apprecicated
Main:
PULSIN PORTB.1,0,Leader ' leader pulse is ~9mS low-going
IF Leader < 850 THEN Main
FOR X = 0 TO 31 ' grab 32 incoming pulses
PULSIN PORTB.1,1,BtnVal(X) ' now measuring high-going pulse widths
NEXT X
' now we'll decode 4 bytes from 32 pulses
FOR X = 0 TO 7 ' sort 1st 8 pulses
IF BtnVal[X] > 150 THEN ' > 150 x 10uS = > 1.5mS pulse period
DByte1.0[X]=1
ELSE
DByte1.0[X]=0
ENDIF
NEXT X
FOR X = 8 TO 15 ' sort 2nd 8 pulses, etc....
DByte2.0[X-8]=1
ELSE
DByte2.0[X-8]=0
ENDIF
NEXT X
FOR X = 16 TO 23
DByte3.0[X-16]=1
ELSE
DByte3.0[X-16]=0
ENDIF
NEXT X
FOR X = 24 TO 31
DByte4.0[X-24]=1
ELSE
DByte4.0[X-24]=0
ENDIF
NEXT X
Lcdout $fe, 2
LCDOUT HEX DByte1, " ", hex DByte2
Lcdout $fe, $c0
lcdout hex DByte3, " ", hex DByte4
PAUSE 200
GOTO Main
shoebuckle
Posted: 01:00am 26 Apr 2012
I have thought of using the Maximite as a controller for time-lapse photography as my Nikon camera has an infra-red remote, but I have no idea of the protocol or what hardware might be necessary.
Has anyone tried this? If so, could you post your schematic?
Cheers,
Hugh
mookster1
Posted: 01:20am 26 Apr 2012
What I would do is get a pin to time how long the pulses were in both directions (how long a zero was, and how long a one was.) This could then be stored in a file and then used to pulse an IR LED. I'm assuming this is something similar to what you're trying to do?
As for using the Maximite as a camera controller, just do lots and lots of research and see what you come up with. If no luck, just try the standard protocols and just play around until something works
Hope this helps
Capacitance is futile - roll on 2012!
