Local Time 05:11 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MOD I/O CNC control with Maximite
Vikingboy
Posted: 10:52pm 18 Apr 2012
I am nearing completion of my homemade CNC machine which is run from mach3 software, this software has a serial Mod I/O interface for adding additional inputs and outputs etc to add more interfaces to the machine from the PC than ,in my case, you get over 2 parallel ports,
What I was wondering is, does anyone know if it is possible to use a Maximite to do this Mod I/O interfacing and if so would I need to use an Olimex Mod I/O card to do so, or do i perhaps only need the Olimex card ?
I really am only just investigating this type of interface and am not at all fully understanding it at the moment, If anyone has used this type of stuff I would be very grateful for any information.
thanks,
Andrew
