Local Time 05:11 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic data in subroutine?
cwilt
Posted: 02:17pm 18 Apr 2012
I was working with Data, Read, and Restore functions and trying to use it inside a subroutine and every time I did it would crash mmbasic. If I put the Data statements in the main code area it worked fine. Is this normal? Any way around it?
jman
Posted: 07:43pm 18 Apr 2012
Hi
The Data should NOT be in in your sub routine
The best place for the Data is at the bottom of your code
But of course you can place it anywhere
A better way to do it is create a "data file" on the SD
Then read the file into an array . This will use less code space
cwilt
Posted: 08:42pm 18 Apr 2012
  jman said   Hi
Hello John. Thanks for the reply.
This sub routine is being used like a library for accessing an external device via SPI interface. Having the Data outside of the routine is not convenient. Storing the data in a file and then loading an array is a possibility but not the best way in my opinion.
Data stored in the routine is the way I wanted it to work but you say it won't so I may look at other methods.
Kind regards,
Charles
cwilt
Posted: 11:34pm 18 Apr 2012
Update....
Loaded released version of 3.2 for UBW32 and problem solved.
Got the data inside my sub routine for a nice compact library.
Thanks again.
