Forum Index : Microcontroller and PC projects : New Version of MMBasic. Version 3.2
     Page 1 of 4
Posted: 04:47am 18 Apr 2012
A new version of MMBasic (ver 3.2) is available for download from:
- http://geoffg.net/maximite.html (for the Maximite and DuinoMite)
- http://geoffg.net/ubw32.html (for the UBW32).
This version introduces a number of new features:
- Defined Functions. These compliment defined subroutines and allows the programmer to add a function to MMBasic that operates the same as the built in functions. See the "MMBasic 3.X Features.pdf" (included in the update) for a tutorial on defined functions.
- Dynamic memory management. This greatly expands the amount of usefully available memory. Now memory for all functions (program, variables and general use) is automatically allocated from a central pool which can be as large as 109KB (with video turned off). This translates into the ability to run very large programs (greater than 3,000 lines) or to allocate huge arrays with more than 20,000 elements.
- A version of MMBasic that runs in a DOS window on Windows XP/Vista/7.
- For the DuinoMite added support for the hardware serial interfaces (COM3: and COM4:). They operate exactly the same as the standard ports and support speeds up to 460800 baud (no, that is not a typo). Added support for measuring the battery voltage, added support for I/O pins 11 and 12 (with caveats) and implemented a reliable method of detecting when the micro SD card has been removed or changed. It is now no longer necessary to reset the DuiniMite when changing the SD card.
Two other improvements in 3.2 are:
- Rewritten the SPI function to improve performance and provide much needed features. The transmission mode and the number of bits to send/receive can now be set and the clock speed has been increased to 3MHz.
- Corrected a number of issues with the UBW32 version related to I2C and the frequency/counting inputs.
MMBasic is being ported to a number of chips and platforms other than the Maximite/UBW32 so now there is a website dedicated to MMBasic at http://mmbasic.com (thanks to crackerjack for the suggestion). This website also has the DOS version of MMBasic (which can be downloaded from http://mmbasic.com/downloads.html). Note that the DOS version does not support features of the Maximite version that are dependent on the Maximite hardware. This includes external input/output, graphics, special keyboard keys, full screen editor and line editing.
The Maximite/UBW32/DuinoMite downloads also contain three other files:
- Bits8 is a library of bit manipulation functions and subroutines that add eight bit manipulation to MMBasic. The library demonstrates the power of user defined subroutines and functions in MMBasic and provides a very useful library if ever you need to "twiddle" bits in MMBasic. These routines were written by crackerjack.
- MaxMan written by Nick Marentes. I included it because it illustrates the speed and capabilities of the Maximite when driving a VGA monitor. It is also fast paced, engaging and addictive !!
- MMBasic Quick Reference for 3.2 written by crackerjack.
Thanks again to the Beta Test team for their help, there would be far more hidden bugs in MMBasic if it were not for their efforts.
The Change Log (included in the update download) details the changes and the MMBasic Language Manual (also included in the download) has been updated to include the new features listed above.
Phew, that must be enough for one post...
vasi
Posted: 08:15am 18 Apr 2012
This is a fantastic release! I hope there is a future version for Chipkit Max32 board.
Vasi
Elvish name: Mablung Miriel
Beyound Arduino Lang
jman
Posted: 08:19am 18 Apr 2012
Fantastic
Big Thank you from Me.
And this is just what the doctor ordered
"Bits8 is a library of bit manipulation functions and subroutines that add eight bit manipulation to MMBasic. The library demonstrates the power of user defined subroutines and functions in MMBasic and provides a very useful library if ever you need to "twiddle" bits in MMBasic. These routines were written by crackerjack"
Thanks Again
Olimex
Posted: 09:18am 18 Apr 2012
great to see the progress with DM hardware features supported and looking forward to see also: CAN, Low power modes, USB host (for HID, USB memory stick as start), USB mass storage through USB and the SD-card, GPIOs on the UEXT and ICSP to be possible to be used by MM BASIC too.
cosmic frog
Posted: 10:05am 18 Apr 2012
I would just like to thank Geoffg for all his hard work on MMBASIC and for making computing fun again.
Thanks.
Dave.
darthmite
Posted: 11:11am 18 Apr 2012
From now i no more say "my God" but "my Geoff" ... he he he
I will be back at home tomorrow and will test this new great release !
And as well continue the little game i am writing atm
Cheers.
vk4tec
Posted: 11:15am 18 Apr 2012
National holiday "MMBasic" day
Andrew Rich VK4TEC
www.tech-software.net
boss
Posted: 03:15pm 18 Apr 2012
Yes, 3.2 is greatly improved code. I had an opportunity to test preleased version and there is lot of space for code and data as well. And extended SPI function allows to connect color TFT display.
boss
DuinoMiteMegaAn
Posted: 06:48pm 18 Apr 2012
MMBasic 3.2 DM Questions
#1. Can the "re-added" Com3 on the UEXT used as GPIO eg digital input/output?
If so, what is the software pin numbers?
#2. Can the "re-added" Com4 on Pins # 11 & 12 be used as GPIO eg digital input/output?
#3. Clarification --> On page 2 in the "DuinoMite MMBasic readme.pdf" you refer to the external view of the external Duinomite 26 pin connector. You show the "software pin #s" which does not correspond to the actual external GPIO pin numbers on the physical connector? (Very confusing)
vk4tec
Posted: 06:53pm 18 Apr 2012
GPS project updated to DuinoMite MMBasic V3.2
+ NMEA Parse
+ LCD 20x4 routines
+ Distance and bearing calcs
+ SD card logging
Odd behaviour - roll back necessary to V3.1R
+ GPS port has moved ? UEXT COM3 ?
+ PIC32 locked up after loading V3.2
+ Control C out of Terra Term did not work
+ SD card needed to be out to boot up
+ Prompt wont respond to carriage return
+ Banner shows DuinoMite MMBasic Version 3.2
+ COM3: 19200 MOD-GPS
Was running DuinoMite MMBasic V3.1R ( pre-release )
PIN RS = 18
PIN EN = 17
PIN D1 = 6
PIN D2 = 5
PIN D3 = 15
PIN D4 = 16
LCD shows banner and then does not see GPS on UEXT
Andrew
Edited by vk4tec 2012-04-20
Andrew Rich VK4TEC
Raros
Posted: 08:23pm 18 Apr 2012
Thank You very very much Geoff.
This is fantastic.
Raros.
f1fco
Posted: 08:42pm 18 Apr 2012
it was not a dream but reality !
thank you Geoff for that
does this version works on CGMMSTICK1 ?
F1FCO, Pierre
73s de F1FCO
CircuitGizmos
Posted: 08:49pm 18 Apr 2012
Yes. Load the Maximite version to the CGMMSTICK1.
cwilt
Posted: 11:36pm 18 Apr 2012
The changes to SPI are great.
Functions are so useful.
I2c is working nicely on UBW32 as well.
Thanks Geoff.
Posted: 02:49am 19 Apr 2012
The DOS version works happily on the 64 bit version of W7.
A very handy addition indeed.
I have added a command to MM Edit to run the code in the DOS window.
Thanks Geoff
plasma
Posted: 04:10am 19 Apr 2012
Thank You very much Mr.Graham.
vk4tec
Posted: 09:15am 19 Apr 2012
Anyone using MMBasic 3.2 on DuinoMite Mini ?
Having issues
1. Green SD card light comes on
2. CTRL-C does not stop program
3. Need to sometimes eject SD CARD to un lock board
4. open "COM3:19200" as #1 , does not seem to work
Andrew Rich VK4TEC
Posted: 09:58am 19 Apr 2012
It definitely works on the DuinoMite Mini, I did most of the development on one.
GeoffEdited by Geoffg 2012-04-20
vk4tec
Posted: 05:21pm 20 Apr 2012
Ok I think I found my problem
print "Made it here ok"
open "COM2:19200" as #1
COM3 hangs the DuinoMite Mini ( UEXT )
COM2 does not hang, and prints "Made it here"
Andrew Rich VK4TEC
vk4tec
Posted: 05:24pm 20 Apr 2012
Yep - that seems to be it
open "COM3:19200" as #1 ( just a one line program )
hangs my DuinoMite Mini
Control-C does nothing.
I have to reset button
Andrew
Andrew Rich VK4TEC
     Page 1 of 4
