Local Time 05:11 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Duinomite mini VGA vs composite
vk4tec
Posted: 03:05am 15 Apr 2012
Hello
At home I use s VGA screen 15 pin
Can the duinomite mini do composite ?
I want to add a little LCD composite to a gps project
What is the diff ? Pin connections ?
Firmware ?
Andrew Rich VK4TEC
www.tech-software.net
Posted: 05:51am 15 Apr 2012
  vk4tec said   Hello
Firmware ?
Hi Andrew,
Yes it can, make up a special cable that has GND on a DB15-pin 7,8 or 10 and video out on DB-15 pin 1,2 or 3 connect these to an RCA connector. Make sure Pin 6 (the VGA/Composite select line is not connected to auto detect that Composite is required.
Use the SETUP command to select video mode (NTSC/PAL etc)
MickEdited by bigmik 2012-04-16
