Local Time 05:01 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Decoding FSK on MM
OA47
Posted: 12:18am 11 Apr 2012
Do you think that it is possible to decode 75 bps FSK with a mite? My initial investigations show that the frequency measurement takes a long time and may not be responsive enough to grab each frequency change even at 75 bps.
vk4tec
Posted: 09:07am 11 Apr 2012
It might be ok with an extrenal PLL ? I know a simple cct can be used to do RTTY like my grandad did.
You lock onto a tone and then the PLL gives a zero or a one for FSK.
75 bps should be easy as with the PIC32
Andrew Rich VK4TEC
NE567 ?
Andrew Rich VK4TEC
www.tech-software.net
djuqa
Posted: 09:21am 11 Apr 2012
MM-FSK sounds like a Great project
Let's start looking at the options
VK4MU MicroController Units
OA47
Posted: 09:33am 11 Apr 2012
Djuqa, I am currently producing the FSK using one mite by tying the RS232 TX to 2 digital I/p and sensing the pulse rise or fall and producing the appropriate frequency.
Best Regards
vk4tec
Posted: 09:38am 11 Apr 2012
I can think of many ways to interface with external pll circuit
You could use mixw32 to make rtty or psk signals
I have some easyradio modules I need to integrate as well
434 MHz 100 mw
Andrew
Andrew Rich VK4TEC
ThierryP
Posted: 06:39am 12 Apr 2012
Graeme,
Some simple external circuitry would certainly do it (2xNE567 or 1xPicaxe 08M2), but I also did provide a possible way forward in MM-Basic that could just about be able to do this, here: Link
Thierry
