Local Time 05:01 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM interrupt
palcal
Posted: 07:58am 31 Mar 2012
Before I embark on a fruitless exercise can anyone tell me if I can use an interrupt within an interrupt, ie in the first interrupt before the 'ireturn' can I start another interrupt. I seem to think the 'ireturns' would get confused.
Paul
AndrewB
Posted: 08:23am 31 Mar 2012
I think that'll depend on the implementation of the interpreter.
I'd give it a try, just make sure you put a long pause in the first interrupt routine so its still executing when you make the second interrupt. You don't have to build your entire system, just lash up a test system.
Have fun!
palcal
Posted: 08:43am 31 Mar 2012
Yes, I've since though that maybe it will work like a nested loop as long as I clear the interrupts in the correct order with an 'ireturn'.
It's just that I have to add another switch to my hardware on another pin with the associated resistors and though I maybe able to save some time.
Paul
Posted: 09:20am 31 Mar 2012
Sorry, you cannot nest interrupts.
Quote from the manual: "During processing of an interrupt all other interrupts are disabled until the interrupt routine returns with an IRETURN."
