Local Time 05:01 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM: Full screen edit/ Composite Monitor
AndrewB
Posted: 09:58am 26 Mar 2012
I'm sure this has been dealt with, but (and I have looked in the forum)....
If a MM or a MiniMM is set to output composite video, which is 50 characters and 16 lines, does the full screen editor then not work either over USB on a PC or (obviously becuse the editor assumes 80x36) on the composite video screen?
Similarly, when connected to a VGA monitor, which isn't quite the 80x36 required by the full screen editor via Terra Term on a PC, does the full screen editor also not work?
jman
Posted: 10:15am 26 Mar 2012
Hi
Works for me
Editor uses the current video resolution
AndrewB
Posted: 10:34am 26 Mar 2012
I should have said I'm using MMBasic 3.1, and am referring to the editor invoked by the "edit" command.
jman
Posted: 06:23pm 26 Mar 2012
Hi
Yip same here
AndrewB
Posted: 09:35pm 26 Mar 2012
Hmmm......
I'll have a look around at Terra Term settings and so on, and see if I can work out where I'm going wrong.
isochronic
Posted: 08:47am 29 Mar 2012
Just wondering, is hyperterm ok for serial comms with MM?
It seems ok for slow speed stuff with other programs, I have found it even works on a usb drive : you put the (XP) files hticons.dll, htrn_jis.dll, hypertrm.dll and hypertrm.exe in a separate folder, and the exe works fine (Windows 7). The saved connections can be used from the menu but the screen shortcuts only work after a registry hack (it's on web). I have only used is 9600/8/N/1 so far, it is fine even transfering files on the the same usb drive, I would guess faster speeds may have usb contention problems.
AndrewB
Posted: 08:18am 31 Mar 2012
Thanks for your input.....
I just didn't recognize what I was seeing and it's working exactly as it should and as described in the manual (doh!)
