Local Time 05:01 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Why is COPY so slow?
boss
Posted: 04:59pm 23 Mar 2012
Can someone advise me why "COPY" command is so slow? In this case program is very short, but copy time takes incredible 25 sec.
boss
09:31:04 B:\>timer=0:COPY "595B.BAS" TO "595C.BCK":? timer
25520
09:32:36 B:\>
'MAXIMITE BASIC v.3.1 18.3.2012
'AUTHOR: JA
'DEMONSTRACNI PROGRAM POUZITI Shift registru 74HC595 PRO RIZENI 7-SEGMENT LED
' MULTIPLEXOVANEHO DISPLEJE, 500 REFRESH/SEC
'====== DEFINICE POUZITI PINU ================================================
LWRITE=14
SCLK=15
SDATA=16
SPIREAD=10 'Funkce SPI nejen posila data, ale take je cte, takze definice RX
'====== NASTAVENI POCATECNI LOG UROVNE PINU===================================
Pin(LWRITE)=0
Pin(SCLK)=0
Pin(SDATA)=0
Pin(SPIREAD)=1
'======= NASTAVENI FUNKCE PINU 2-VSTUP,8-VYSTUP ==============================
SetPin LWRITE,8
SetPin SCLK,8
SetPin SDATA,8
SetPin SPIREAD,2
'======== DEKLARACE POLI =====================================================
Dim CAS(4)
Dim ZNAK(16)
Dim ZNAKN(16)
'======== PLNENI POLI DATY ===================================================
For I=0 To 15
Read ZNAK(I)
If I=0 Then ZNAKN(I) =&HFF Else ZNAKN(I)=ZNAK(I)
Next I
'============= Definice INTERRUPTU ===========================================
SetTick 1000,DEJCAS ' INTERRUPT each 1000mS
READTIME ' First reading
'**************** MAIN *******************************************************
' Pulse 0.001 means that Write Pulse is 1uS (10-6 sec)
D= SPI(SPIREAD,SDATA,SCLK,&H80)
D= SPI(SPIREAD,SDATA,SCLK,CAS(0))
Pulse LWRITE,0.001
D= SPI(SPIREAD,SDATA,SCLK,&H40)
D= SPI(SPIREAD,SDATA,SCLK,CAS(1))
Pulse LWRITE,0.001
D= SPI(SPIREAD,SDATA,SCLK,&H20)
D= SPI(SPIREAD,SDATA,SCLK,CAS(2))
Pulse LWRITE,0.001
D= SPI(SPIREAD,SDATA,SCLK,&H10)
D= SPI(SPIREAD,SDATA,SCLK,CAS(3))
Pulse LWRITE,0.001
' L=L+1 ' PRO MERENI POCTU REFRESH - VYJMOUT APOSTROF
If CAS<>0 Then READTIME
Loop
End ' MAIN
'=============*INTERRUPT SERVICE*=============================================
DEJCAS:
CAS=1
IReturn
'SUBRUTINA PRO CTENI CASU, POUZIVA POUZE GLOBALNI PROMENNE, PROTO JE BEZ PARAM|
Sub READTIME
CAS(3)=ZNAKN(Val(Left$(Time$,1))):CAS(2)=ZNAK(Val(Mid$(Time$ ,2,1))) And &H7F
CAS(1)=ZNAK(Val(Mid$(Time$,4,1))):CAS(0)=ZNAK(Val(Mid$(Time$ ,5,1))):CAS=0
'Print L;Chr$(13);: L=0 ' PRO MERENI POCTU REFRESH - VYJMOUT APOSTROF
Return
'======= DATA FOR 7-SEG DISPLAY =====================================
'Data &H80,&H40,&H20,&H10 'D1,D2,D3,D4
Data &HC0,&HF9,&HA4,&HB0,&H99,&H92,&H82,&HF8,&H80,&H90 '0-9
Data &H88,&H83,&HC6,&HA1,&H86,&H8E 'A-F
BobD
Posted: 05:19pm 23 Mar 2012
  boss said   Can someone advise me why "COPY" command is so slow? In this case program is very short, but copy time takes incredible 25 sec.
boss
probably takes so long because you are copying to and from the SD card. The writes and the reads are competing for access to the card.
boss
Posted: 05:56pm 23 Mar 2012
Yes, I was considering the same reason but still a copy time of more than 25 seconds seems be too long. Yesterday I tried to copy a ~5MB file and this lasted the whole night.
Posted: 01:16am 01 Apr 2012
I have had a look at the code and it is easy to see why it is slow... the copy is done on a byte by byte basis. Adding some buffering (2KB) made it run over 100 times faster.
I will put this in 3.2 (due in about 4 weeks).
boss
Posted: 02:43am 01 Apr 2012
I thought so. Thank you for explanation.
boss
